Gas Lite
Old Dec 12, 2006 | 08:02 AM
Swazey's Avatar
Gas Lite
for the past couple of months my gas lite has not gone on, even when i am below empty. idk why this happened. now that i think about it... around the same time, when the car is off and the headlights are on, there is no beeping sound or warning sound letting me know the lights are still on.
does anyone else have this problem? or know how to fix it?
Old Dec 12, 2006 | 08:15 AM
MaximaSE96's Avatar
Maxima Owner
the light goes on when there is about 2-3 gallons of gas left.....i would start checking fuses
Old Dec 12, 2006 | 08:44 AM
aznprid972's Avatar
My guess would to check the gas light bulb itself. It's a #74 bulb I believe. Also, for the little chimmer, check to see if it's plugged in. Remove the panel between the steering wheel and the petals. It should be held in place with 2 phillips screws. The chimmer should be right under where the fuse box cover is located on the inside of that panel you unscrewed.
Old Dec 12, 2006 | 08:50 PM
Swazey's Avatar
all the fuses are fine, i checked them before posting.
Old Dec 12, 2006 | 08:51 PM
Swazey's Avatar
thanks for the input. im going to try this out tomorrow. ill keep you posted. much appreciated
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
