Crank position sensor POS and REF
So here I am, trying to figured out why my max wont start. Cranks and Cranks and Pops and cranks and pause and crank. I have all the grounds installed, I already regreased my starter. So Im trying to clean the 2 CPS, I know where the ref is, but the POS is kinda sketchy. Does someone have a picture of that sensor (CPS POS)? Im pulling on a sensor that I think its the pos, but im not sure. Theres no connector on it, only a line covered in a white insulator and has a black end that connects to the sensor. Anyone can help me on this?
Thanks alot guys
Thanks alot guys
One is under the crank pulley
the other is on the front of the tranny. (stand in front of your car, Look at the radiator cap look forward and down to the ground, you should see it, its black)
test with a multi meter. Clean them off and test with a multi meter. If they are not in spec (waay out of spec) replace them. Better swap the sensor from a working max just to be 100% sure.
