Fog light question ('97 GLE)
Old Dec 16, 2006 | 04:08 PM
heynow's Avatar
Hi guys, i've read somewhere on this forum that 4th gen GLEs are pre-wired for fog lights. I've looked around and i'm not sure if i see the harneses. Doesn't anyone know for sure, if so, here are the lights i'm considering getting:
http://cgi.ebay.com/ebaymotors/97-99...63438689QQrdZ1
Thanks!
Old Dec 16, 2006 | 04:15 PM
jsidhu's Avatar
it says OEM Fit.. so i dont think it will be a problem..
Old Dec 16, 2006 | 04:16 PM
jsidhu's Avatar
oh, and it should be real easy to wire even if urs is not prewired, like my GXE, I just added a relay and ran them off the parking lights.
98_maxi's Avatar
it has to be pre-wired, check by the turn signals,inside the bumper there suppose to be plugs taped up, and also u can check fuse box(by power steering), it suppose to have plug for relay....
and if u by these fogs, u also need fog relay and SE turn signal switch, unless u wanna run different wiring for fogs.
Old Dec 16, 2006 | 10:10 PM
heynow's Avatar
i think there are some wires tied together under the right side of the bumber (i'll double check tomorrow) i've also checked the fuse box, and it doesn't have the fog light fuse. If also need fog relay and SE turn signal switch, it might be too much of a hassle to look "cool"
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
