hesitation/misfire at 2800rpms, only noticeable in 4th and 5th gear
Old Dec 18, 2006 | 12:22 PM
acidspit86's Avatar
ill be cruising in 4th or 5th, at ~2800rpm and punch it to the floor, ill feel a misfire or hesitation for maybe 1 second then it goes away. would this be the coils or something else like a tps or maf?
Old Dec 18, 2006 | 12:32 PM
Bassman607's Avatar
In the old days when we used carberators, the accelerator pump was broke or feeding too much fuel. Usually it was a broken Acc. pump. Sounds like you're running lean when you punch it. Are you gtting enough pressure at the injectors? Possible fuel filter clogging?
Old Dec 18, 2006 | 12:42 PM
madisonmxma's Avatar
a dirty MAF sensor would give you symptoms like that but you would probably be seeing those symptoms in more than 4th and 5th gear.
Old Dec 19, 2006 | 08:02 AM
acidspit86's Avatar
yeah my fuel filter has like 30k miles on it or so, i guess it couldnt hurt to change it and give it a try
Old Dec 19, 2006 | 10:27 AM
i30ds's Avatar
Armed and Dangerous
MAF sensor.
Old Dec 19, 2006 | 11:17 AM
acidspit86's Avatar
fuel filter was clogged as hell, and it fixed it
Old Dec 19, 2006 | 09:03 PM
happy4444's Avatar
how do you claen the maf sensor?? i had the same problem but already changed fuel filter and it only went away for a little bit
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
