96 remote
if by bottom you mean other end from the large grey button, that is the panic button (hold it down to set off the horns and lights. use the unlock button to turn it off). if you want to unlock all of the doors, hit the unlock button twice. if you want to roll down the front windows hit and hold the unlock button. no rollup feature.
Originally Posted by Wassup2114
What is the bottom button supposed to do anyway? Nothing seems to happen when I hit mine.
Originally Posted by 2da mizzax
panic sets of the horns and the lights. lock button only sets off the horns if pressed and the car is already locked in which case the lights will flash once and the horn will beep once.
there's even how-to's in the stickies on how someone modified their car to make a sound when they press the lock button instead of just the lights flashing.
nothing aftermarket about it. and no idea why it would sound like it. use the remote to lock the doors.....no sound. keep hitting the lock button..toot toot.
mine does that, didn't know about the dome-light though might try it.
the fact that they only put a rolldown and not a roll-up seems stupid to me (way to go NISSAN!!
I have an idea for using a switch and an auto-relay to bypass the signal sent to rolldown the windows to the starter so that when the switch is activated I could use my Fob-key as a remote starter for those cold winter mornings and use the window roll-down in the summer. But i've been swamped with work and have had other issues with more priority in the MAX to deal with it, I'll get to it eventually...
p.S.: Procrastination is a biatch!
Originally Posted by albo
i was a about to ask about that.. maximas . dont beep after you lock the doors... ?
ok . finally. found it. i thought i had read something about it.. i guess here is a way you can make the car beep after you look your doors ... here is the link.. it was in the how to's http://www.vqpower.com/v2/modules.ph...howpage&pid=39
Haha I aint stupid, I replaced it awhile back and it worked like on and off, then finally stopped. Just 2 seconds ago I bought another one and popped it in, it still don't work. I tryied reprogramming and I also tried unplugging the module and reconnecting.
I donno what it is...
i'll go to a junk yard and get a horn (doesn't even have to be from a Maxima) and replace the piezo electric horn for that, should work the same in theory.
yea i looked into it.. i just put it there if anyone wanted to explorer into that.. me personally.. id rather it be quiet... if someone trys to get in then .. man honk like there no tomarrow... LOL..
ToTheMax305
Sep 23, 2015 09:11 PM
trungg86
Sep 4, 2015 04:58 AM
Is it broken?
