Subtle whistling noise at idle. Vacuum leak?
Old Dec 22, 2006 | 06:58 AM
petemo95se's Avatar
Just curious if anyone has experienced a slight whistling noise. This can be heard when you are idling and sitting still. Sometimes it changes pitch when you turn the steering wheel OR give it the gas.
My suspicion is there may be a slight vacuum leak that is causing it. How do you check for such a leak? (Spray test or something?)
Any thoughts would be appreciated.
Old Dec 22, 2006 | 07:19 AM
Blackwind's Avatar
it is a leak, spray some break parts cleaner near all of the VAC areas and you should find it. or you can have fun with your car and dissasemble it.
Old Dec 22, 2006 | 09:30 AM
aznsap's Avatar
ya i have the same problem. you can try spraying throttle body cleaner, brake parts cleaner, i think even wd-40 will work in areas until you hear the engine struggle. i just haven't found mine yet.
Old Dec 22, 2006 | 09:12 PM
drewsblackmax's Avatar
not your cai is it? i have a short ram and if i listen really closely there is a suction noise. just a thought
Old Dec 22, 2006 | 10:18 PM
Wassup2114's Avatar
I have a whistling that only occurs at a certain throttle position, around 1/2, in all gears. It varies in pitch a bit as you press the throttle a little past 1/2 then stops completely. I'm not sure what it might be. I have no whistle at idle, though.
Old Dec 24, 2006 | 08:55 AM
RA030726's Avatar
I'm nutty for Nissans
NORMAL. Youll hear it very good with a mid pipe.
Old Dec 24, 2006 | 11:23 AM
Pieps's Avatar
I have that whistle at about half throttle with my short ram
Old Dec 24, 2006 | 03:47 PM
MDeezy's Avatar
could be an alternator whine. . . the whine goes away usually after you rev past 1k
Old Dec 24, 2006 | 04:13 PM
shiftnatredline's Avatar
Godzilla
if it changes when you turn your wheel it could be your power steering pump. sometimes they whine.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
