"woosh" sound during heavy acceleration
Old Dec 31, 2006 | 03:17 PM
ComradeJew's Avatar
Noticed today that at almost WOT (i am gonna say 3/4 WOT) I hear a woosh sound past the 4K RPM line. Seems like a vacuum leak but it runs idles and drives fine - so gotta be a minor leak of some sort.
Any ideas where to look?
Thanks!
Old Dec 31, 2006 | 03:32 PM
2da mizzax's Avatar
"Swoosh" sound during heavy acceleration
get rid of the Nike tires and get some BF Goodrich.
Old Dec 31, 2006 | 08:33 PM
MOHFpro90's Avatar
My friends car does this, with his CAI though...you can hear it, its sucking sound, then a slight whistle(turbo like). Check your intake tubing...maybe?
Old Dec 31, 2006 | 08:45 PM
Apparition's Avatar
Ichiban King
It's a normal thing for the PRCAI, my friends and I both have the same sound..
Old Dec 31, 2006 | 09:07 PM
matty's Avatar
Blow Off Valve
Old Dec 31, 2006 | 09:58 PM
packetscan's Avatar
I get the Same sound from the IAC, Like a sucking sound, however it only happens once in a while and their is a loss of power when the sound is present.
Old Jan 1, 2007 | 01:07 AM
ComradeJew's Avatar
Exactly what happens to me... where exactly is the IAC? And what should I check there?
Oh and I got BF's now
Old Jan 1, 2007 | 01:26 AM
matty's Avatar
Its located on the Intake manifold just past the TB.
The IACV doesnt really do anything at WOT. Its main reason for living is to tranport air from one side of a closed TB to the other and supply air to the motor, when the Tb is Closed
-matt
Old Jan 1, 2007 | 02:13 AM
ComradeJew's Avatar
I've just come home and noticed that under full WOT i hear lots of wooshing sound, maybe a better description would be air sucking sound. If I let go of the pedal and hold it at 1/2 WOT - I still hear the sound but to a lesser degree...
Old Jan 1, 2007 | 03:17 AM
AceofSpds's Avatar
wat
Take the turbo off
Look for a small hole or crack in your intake
Old Jan 1, 2007 | 07:43 AM
MOHFpro90's Avatar
Yeah, I knew about that, but his(my friends car) is on a Focus, its a marcymotorsport CAI.
Anyway, guess some intakes just make that sound. I would assume it would be that.
Old Jan 1, 2007 | 08:05 AM
maxima_kenny96's Avatar
congrats on the turbo set up, what bov is giving you that wicked sound?
Old Jan 1, 2007 | 12:41 PM
ComradeJew's Avatar
Craptastic(TM)
Old Jan 1, 2007 | 02:27 PM
lol...thats a new one havent heard of them.
Old Jan 1, 2007 | 04:47 PM
ComradeJew's Avatar
Played with the air intake today and noticed that when its running, I can hear a small bov-type sound - like very light air suckling sound when i let go of the gas (that's when my head is in the engine bay... couldn't find any leaks tho )
Old Jan 2, 2007 | 08:18 AM
L0R1DA's Avatar
Check all your 1" diameter hoses (they are mostly vacuum lines) for swelling, cracking, or other wear (replace as needed), Change your PCV valve ($3-6), Clean your EGR tubing (not the valve itself:replace if bad) ($3 for can of solvent)... hope that helps!
Old Jan 2, 2007 | 10:33 AM
MOHFpro90's Avatar
Also check to make sure you TB, IACV, etc...bolts are all tight...granted, it would be a slim chance, but you can try.
Old Jan 2, 2007 | 12:37 PM
ComradeJew's Avatar
I'll give those suggestions a try later on
Old Jan 2, 2007 | 07:22 PM
Grand_hustle17's Avatar
if it makes a whistling sound thats perfectly fine, that like every maxima, i dont hear mines but only when im watching the video of my races
Old Jan 2, 2007 | 08:30 PM
ComradeJew's Avatar
A little bit of more investigation:
The sound that I hear sounds as if a window is slightly open and air is rushing in at high speed and the sound is not uniform. Also, seems like acceleration is sluggish...
Old Jan 2, 2007 | 10:36 PM
MOHFpro90's Avatar
Something(leaf, stick, etc) caught in the intake snorkel? Um, make sure your snorkel is all the way in the air box(mine comes out easily). Ill let you know if I have any other ideas.
Old Jan 3, 2007 | 05:07 AM
jacobmh27's Avatar
I hear the same thing too
Old Jan 4, 2007 | 11:05 AM
Spartuss's Avatar
I hear the same hissing/air sound under light accelration as well. I am all stock however with no CAI.
Old Jan 4, 2007 | 11:15 AM
ThurzNite's Avatar
Do our cars have swirl control valves? OBD-II code P1130
Jae
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
