New VSS didn't clear P0500
Old Jan 2, 2007 | 05:20 PM
mikeyen's Avatar
My title pretty much says it all...
I run into a comment once in a while where some folks are taking out the cluster and tightening some screws. Can someone point me there?
It seems like if the VSS was bad, the speedo would read zero. It doesn't; it's pretty accurate. It never drops to zero, except when it's stopped. My theory is that there's a wire somewhere between the speedo and either the speed control or the engine control units. Does that sound right?
Car's running perfectly. So I don't understand why that yellow light with a P0500 would be there.
Old Jan 3, 2007 | 09:42 AM
i30ds's Avatar
Armed and Dangerous
You need to tighten the screws on the back of the gauge cluster. If that fails, then it's time for a new speedo gauge.
Old Jan 3, 2007 | 10:33 AM
mikeyen's Avatar
Can you point me to instructions on how to tighten the screws?
Which ones are they?
It looks to me that to get the cluster out, I remove the panel above my legs, then take off the steering column cover, then the trim around the guages, then pulling the guages, right? That doesn't seem too hard, at least compared to changing a water pump and a radiator. Are we talking two hours here?
Old Jan 3, 2007 | 02:40 PM
loverholic's Avatar
iAMIXAM!
bump.....
i wanna know what two screws to cause i have a lil prob with my speedo shorting out to... and i wanna change my bulbs while i am back there....
Old Jan 3, 2007 | 07:52 PM
i30ds's Avatar
Armed and Dangerous
Just tighten up the screws on the back of the cluster that are on the speedo half. No need to mess with the others. If your still not sure, just tight them all.
You are correct about about removing the cluster. Remove the panel above your legs, then the steering wheel column trim, then the black trim around the cluster, and finally the 3 screws that hold the cluster in place. It will not take more than half an hour.
Old Jan 4, 2007 | 02:31 AM
loverholic's Avatar
iAMIXAM!
thanks for the PM i30ds... i will give it a shot and let you know how it go....
Old Jan 4, 2007 | 11:35 AM
mikeyen's Avatar
Thank you. I'll give it a try.
In the event I need to change a speedo, what are the dealers getting for this job? I know this has to be done by the dealer, and I'm reluctant to go with a junkyard one.
Old May 23, 2012 | 02:25 PM
kasanova25's Avatar
SAME ISSUE
i know im late but i have the same problem i though it was because i did the speed limiter cut of the pink and blue wire...i cant pass inspection.. i have tighten the screws and a new VSS help please..i have also tried to add wire to the limiter and electric taped it back together
Old May 23, 2012 | 07:14 PM
Trini Boom's Avatar
There was no need to add on to this thread. The post stated that if tightening the screws DOES NOT WORK, you need to REPLACE THE SPEEDOMETER GAUGE.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
