DEK Emange ultimate and Dyno jet= not so good
Old Jan 2, 2007 | 05:54 PM
95turbo gxe's Avatar
Ok Ill post the sheet when I get home.
My only mods are a buget Y-pipe,Cai, And emange Ultimate
My Timing is advaced to 11 degrees above stock and my air fuel was at a mostly 13.4
I have a red line of 7200 rpms. My fist runs was done at 10degrees and we moved up to 11 and seen a 2 hp increase. I had no nock on dyno. the higest knock level seen on the eu logger was 26 at about 7000.
Ok I made peak power at 6200 rpms and then it start to fall off
peak torque was made at 3800 rpms
The sae corrected #s are 195.74 whp and 192.09 wtq
Are these good #s for the mods I have. What would a stock dek make.?
And why did the power fall on the top end?
Old Jan 2, 2007 | 07:06 PM
matty's Avatar
Is your VIAS opening ?? Did you take your Manifold apart and make sure that the valves are functioning properly ??
-matt
Old Jan 2, 2007 | 07:13 PM
-matt
yeah its working we set it on the dyno and played with it. I had it set to open at 4800 and it made a little dip in curve so I tyed 5000 and lost torque and horsepower. then I tyred 4700 and its a nice smoth curve on the dyno.
I about to post the graph
Old Jan 2, 2007 | 07:16 PM
konak85's Avatar
those are good numbers. how much did it fall off after 6200? post the dynosheet
Old Jan 2, 2007 | 07:44 PM
Tatanko's Avatar
Bacon Lover
Those are solid numbers, but I still see you able to get more out of it. Why did you post this here and not dyno discussion?
Old Jan 2, 2007 | 08:19 PM
run 1 was done in 4th gear
run 2 was in 3rd with 11 degees advance
and 3 we let the car cool off and it went lean for some reason
Old Jan 3, 2007 | 04:49 AM
MaximaSE96's Avatar
Maxima Owner
i dunno they seem kind of low to me.....my corrected numbers were 178.8 whp and 185.5 wtq and all i have is a cat-back no VI at all and not fuel tuning at all...something just doesnt seem right in your case....or i could just be on a whole lot of crack that i dont know about
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
adamgalazka
Sep 8, 2015 01:27 PM
