need help...which fuse is for the clearence light and the turning signal lights?
Old Jul 3, 2001 | 07:12 AM
alloutmax's Avatar
i try to rewire my clearence light but when i turn them back on the clearance light and the turning signal lights went out. it seems the fuse just blew out because maybe i rewired it wrong. does any one know which fuse i must replace and where to get it. thanks
Old Jul 3, 2001 | 07:24 AM
Daniel B. Martin's Avatar
Please check fuse #5 (7.5 amps) and fuse #14 (7.5 amps) in the passenger compartment fuse block.
The passenger cabin fuse block is located behind a pull-out panel in the lower dashboard, to the left of the steering column. It has three columns of fuses.
Numbered from bottom to top....
- the left-hand column contains fuses 1 - 11
- the middle column contains fuses 12 - 26
- the right-hand column contains fuses 27 - 40
The numbers are molded into the plastic fuse block. They are not easy to read. A flashlight will be helpful.
Replacement fuses may be purchased at any auto parts store or mass merchandiser (K-mart, Wal*Mart, etc.).
Old Jul 3, 2001 | 08:18 AM
redmaxpa007's Avatar
i SeE what you did therE
Daniel B. Martin is the man!!!
i was all geared up to answer this and then i saw he already answered it... doh...well needless to say hes got all the info...
Old Jul 3, 2001 | 08:47 AM
alloutmax's Avatar
thank you very much for helping me, what you said did work. thank you again.
Sport
Jul 3, 2017 05:40 PM
03VQMAX
Oct 2, 2016 09:36 AM
rbaker100
Aug 28, 2015 08:11 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxima297
Aug 3, 2015 12:50 PM
