S/C, Turbo or 3.5swap
Originally Posted by brs2c
So when yall are saying that the 3.5 "drinks oil" it is not burning the oil, like slipping past the rings, it is coming out of the pressure relief valve on the head?
I still would be pissed a little, but power would make up for it.. The one I wouldn't want is a "headgasket eater" as the guys at Nissan called it.
Originally Posted by nismology
It's unfortunate that nissan skimped out on the FWD 3.5 headgaskets. They're 2-layer as opposed to the 3-layer 350Z/G35/FX35 etc. RWD gaskets.
Also, I am not familiar with the composition of the maxima's 3.5's, but has anyone tried dropping in some ARP head studs and torquing them way down? I run 22psi on my eclipse daily with an felpro head gasket (found at most auto stores) torqued to 90ft lbs and my buddy runs 35 psi on his evo with the same stock replacement gasket. If it is torqued down enough it should be hard for oil, or combustion to really start getting into the layers and destroying them.
Now if you're talking about preventing the headgaskets from failing, the OEM 3-layer 350Z is a cheap upgrade. ARP hardware is unnecessary until very high HP levels.
But why do that?
You risk the chance of stripping out the block or the head.
Just get a MHG, or some sort of upgraded head gasket, ARP studs and torque em to their specs.
Another 80-150 bucks for a good head gasket and correct assembly is well worth it.
I'm pretty sure the Evo's head gasket's are part metal composition... Not to mention the engines are built for boost, unlike the VQ35.
PS: What year is your eclipse??
Mike
Mike
Just get a MHG
BTW, ARP hardware is COMPLETELY unnecessary on an n/a or mildly boosted (circa 400 WHP) 3.5 except for their rod bolts if you plan on revving past 7100 RPM or so. Over on my350z.com, ARP L19 head studs are used when the horsepower goals are in the 500+ WHP range.
I know I'm a noob but...If a leak is small enough in the headgasket it is possible for it to burn oil and can also be accompanied by overheating. My buddy was burning a little oil on his eclipse on stock boost when he cranked up the boost it blew. We took it apart and there were two flaws in the HG, one was huge where it had blown, and there was another very small indention from the cylinder to an oil passageway which had been causing his oil buring problem.
I am going to call tilley tomorrow and see what he say, but I do like the idea or a boosted 3.0. I just need to nail down some prices, so far I know what the s/c kit cause and I seen a full turbo kit for 3100 just need a price on a 3.5swap now
brs2c.
Shoot me an e-mail with the specs/pictures of your eclipse...
I would like to talk with you about it.
blackmaxx96@yahoo.com.
Thanks,
Mike
BTW... welcome to the .org!
Thanks,
Mike
The only reason I suggested the head bolts is because its easier and cheaper than the head gasket option, but definately not necessary for lower hp levels.
BTW, welcome to the VQ game.
Well the OEM 350Z head gasket is like 60-70 bux for both and combine that with 16 new OEM head bolts for 81 bux and you've got a solid setup that can handle 450 WHP. The ARP head studs cost like $225 on their own. If you you want 500 WHP and beyond i'd get ARP L19 studs and either a Cometic or HKS HG and start building the bottom end. But this is a moot point because most VQ35's will never come close to these HP levels.
3.5 FTGay.. If it didn't come in your car from the factory, then I'm not gambling with the 3.5. I would trust only someone like Tilley with that engine. Too many stories of burning oil and destroying head gaskets.
We do have a lot of guys who have no probs, like Nismology and GoalieKeg.. But quite a few of the guys DO have catchcans that fill up rather quickly.
Originally Posted by StrangeMAX
dont forget about tavarish ...or even maybe tjmax
Originally Posted by t6378tp
yeah I was trying to pm them but the member search is down so I looking for a thread they posted on
Originally Posted by adampit
well the s/c is no longer in the picture, I will be getting either the 3.5 swap or rear mounted turbo setup.
I am currently pricing parts for the turbo and getting some specs on a smaller turbo with less lag want the boost around 3200rpms. I going to wait a few weeks to see how street's project works out
I think with the rear mounted setup you may not be able to run as much boost as some may like. a 3.5 will be a nice Hp gain from a stock y piped Max. Add a 75 shot and I think you'll be satisfied for while.
well if I run the turbo setup I will only be running a max 8psi and at the track a 50shot of nitrous from 0-3500rpm to get out the hole
but if I go with the 3.5swap what you said mdeezy is excatly what I will be running .. with a 3.5 I am hoping for mid-high 13 sec n/a and low 13 to high 12sec nitrous 75shot
Originally Posted by Nismo3112
I ran a 13.8 w/ a 2.3 60ft.. With a good launch I believe I could have gotten a 13.4-13.5
well like I said I will wait a few weeks see how streetz setup is working out do more research but if all else fails 3.5 with a 75shot here I come
