Brake Light Is Illuminated!!!!!!!!!!!!!
Old Jan 7, 2007 | 05:40 PM
Black Maxima
Okay, my friends 96 Maxima has the brake dummy light on. What is the cause of this? His fluid it right on the LOW line. He noticed before that he would jiggle the e-brake lever and the light would sometimes go on or off. His e-brake is disconnected. Why his is dashboard brake light on?
Old Jan 7, 2007 | 05:46 PM
NmexMAX's Avatar
dot dot dot ...
Add fluid, end of problem.
Old Jan 7, 2007 | 05:58 PM
C++
The Alternator is on its way out.
Old Jan 7, 2007 | 06:25 PM
Black Maxima
I told him that he should add fluid. He is such a cornball.
Old Jan 7, 2007 | 06:26 PM
Black Maxima
C++, it's not the alternator, the battery light isn't on.
Old Jan 7, 2007 | 06:37 PM
rockfordmaxII's Avatar
cornball, ha
Old Jan 7, 2007 | 07:59 PM
Nissan 6's Avatar
I don't know.
Old Jan 7, 2007 | 08:18 PM
Fr33way™'s Avatar
Wild for Width
Low fluid/leak/air/ebrake <-- only causes.
Old Jan 7, 2007 | 09:11 PM
Black Maxima
His e-brake is FAWKED up. He is a cheap-azz too. I'll put more fluid in there tomorrow because he doesn't even know how to do it.
Old Jan 7, 2007 | 09:28 PM
spadez911's Avatar
if his fluid is at the low level then he needs to check his brakes pads..dont add fluid to the reservoir...tell him check his brakes first
Old Jan 7, 2007 | 09:44 PM
MDeezy's Avatar
You should have known better, as soon as you knew his fluid was right on the low line, you should have told him to add more fluid and see if the light goes away.
Old Jan 7, 2007 | 09:46 PM
andrei3333's Avatar
as BORAT would say: " umm This post, not so smart" !!!
Old Jan 7, 2007 | 10:00 PM
Black Maxima
I did tell him. He didn't feel like driving to get any fluid and told me that that wasn't the problem. This thread was more to show him that he's geeeeeeeeey.
Old Jan 8, 2007 | 12:20 PM
gtpsycotic's Avatar
the same thing happened to mine and i changed the break and the fluid and the break light is still on as well as the battery light and the alternator is new. so i say that its an electrical problem cause i need help as well
Old Jan 8, 2007 | 01:05 PM
Zach95SE's Avatar
We all know you are the only person from CT on here with a '96 so don't try to hide.
Old Jan 8, 2007 | 03:15 PM
Black Maxima
Hahahahahahaha
Old Jan 8, 2007 | 03:19 PM
Black Maxima
Old Jan 8, 2007 | 03:21 PM
2da mizzax's Avatar
uhh. when your brake light comes on you dont just add fluid. the light is there for a reason. you CHECK YOUR BRAKES.
Old Jan 8, 2007 | 03:23 PM
Gismo-T's Avatar
B!tch We Got a Problem
Aaron you're so
Old Jan 8, 2007 | 03:37 PM
Black Maxima
His breaks have been dusting pretty bad. But anyway, like I said earlier he is a tool, just ask "sickmax" in the 5th Gen forums.
Zach95SE's Avatar
Clearly a photoshop.
Old Jan 8, 2007 | 03:39 PM
Black Maxima
Hahahahahahaha
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
