1998 I30 Stalls Within 2 Seconds During Cold Start
Starts up every time without a problem, but stalls every time within few seconds (during cold starts only), if I give it gas for about a minute, the problem goes away. My guess is the MAF sensor, cuz I read someone else having the same symptom somewhere. Has anyone else experience this?
VERY much like this guy's:
http://forums.maxima.org/showthread.php?t=505888
More info for my problem:
- Automatic
- 100K miles
- takes just 1-2 cranks to start, very easy
- No CEL/SES
- Loud squeel(squeek?) noise, squeels faster as I push for more gas (as RPM rises)
- Noise gone and problem gone after I push the gas for 30-60 seconds
- Idles around 600 RPM in "D" afterwards, very smooth, drives just like new
- Automatic
- 100K miles
- No CEL/SES
Thanks for the tips. I'll try to find where the coolant temp sensor is located.
i30ds: I think you posted instructions on how to check the fuel pressure from my other thread (when my 2000 I30t stalled), so I'll check that out.
It doesn't seem like my I's like the winters, sigh...
yes that other guys problem was mine
did it again today but this time the rpm dipped to like 200-300 then got back to 1300 or so and idled normal from there
this is weird, i need to fix it, next paycheck im going to my mechanic and if he doesnt fix it im going to the dealer, caues im not willing to get stuck in the winter somewhere
Thanks for all the tips guys, keep it coming.
well no i had the problem u described just two days ago, one user ,L0R1DA, told me its a PCV valve and it should be replaced, im going to take his word for it and do that hopefully within a week or two
the weird thing, and what leads me to believe its an air presure/intake problem is that when u start the car as it immediately starts to die (rpm droppping within like 1 second) u hit the gas slightly and she remains at normal idle rpm, its like she needs a little push to start intaking the air or something, this is weird, but i will visit a dealership within 2 weeks
I have the same problem it's flooding if you step on the gas it start fine.I have not taken it apart yet but my guess is leaky injectors or I read somewere the lower o-ring on the injector may be bad car has 250000 kms
I had a simular problem it was with inconsitant stalling and sometimes no starting... turned out to be a broken wire that when cold contracted slightly and no longer made contact. The wire had something to do with my fuel pump I believe, i would get into more detail but a friend fixed it for me so I never really got a chance to see the nitty gritty of the whole ordeal.
The carstarts every time if you step on the gas when cold
work fine if it's hot no check engine light no codes not the iac cleaned that good on gas runs fine after about 2sec when cold.strong gas smell and it not leaking anywhere that i can see. The car floods after it has been sitting for awhile you can smell the gas before you start it.
trungg86
09-04-2015 05:58 AM
