Odometer Broken!!!!! Please Help!!!!
Old Jul 3, 2001 | 06:25 PM
JLMaxima
I was driving my 1996 Max SE on a short trip from college to my families home in Ohio, when I noticed that my trip odometer was stuck at 299 and was just about to roll over to 300 miles. I reset the trip odometer but it did not record any more miles while I was driving about 45 mph. It is stuck and my odometer won't record any more miles. I know this is sort of a good thing, but I don't want to sell my car without the odometer working and it will screw up my oil change appointments. Please tell me what the problem could be, so that I could possibly get it fixed. I tried the fuses, but they were all ok. Thanks for any info..
Old Jul 3, 2001 | 07:05 PM
Daniel B. Martin's Avatar
More information please
Originally posted by JLMaxima
I was driving my normal trip from college to my families home in Ohio, when I noticed that my trip odometer was stuck at 299 and was just about to roll over to 300 miles. I reset the trip odometer but it did not record any more miles while I was driving about 45 mph. It is stuck and my odometer won't record any more miles. I know this is sort of a good thing, but I don't want to sell my car without the odometer working and it will screw up my oil change appointments. Please tell me what the problem could be, so that I could possibly get it fixed. I tried the fuses, but they were all ok. Thanks for any info..
When posting a technical question it is helpful if you specify the model year of the Maxima.
Does the speedometer work normally?
Old Jul 3, 2001 | 09:23 PM
WaarrEagle's Avatar
He edited his first post to include the model in case you didn't notice. Its a 96 SE.
Old Jul 3, 2001 | 10:35 PM
Rich96SE's Avatar
I have the same model with the same problem. I called the dealer and they said that it would be around $300 to replace the entire odometer unit and the labor.
Old Jul 4, 2001 | 06:56 AM
He still prefers to make speedometer function a secret.
Old Jul 4, 2001 | 02:03 PM
92ZexMaximaSE's Avatar
I'm in the same boat as you.. I have had a broken odometer for about 1 month now but I havent been driving the car as much since I dont want to be busted for odometer fraud..I plan on fixing it once this 4th of july holiday is over and done with..
Old Jul 5, 2001 | 08:59 AM
Slim's Avatar
JLMaxima - if you need a speedometer, I have one (the whole instrument cluster for a 96SE minus the tachometer). It's fairly easy to swap out. Let me know.
Old Jul 5, 2001 | 12:15 PM
Rich96SE's Avatar
Has anyone ever done the replacment of the odometer themselves? I would like to change my out so it will work. Does anyone have instructions on replacing the dash cluster?
Old Jul 5, 2001 | 01:40 PM
GTNUKE's Avatar
I had the same thing happen to me.
I also have a 96 SE. I have 75,000 miles on the car. The trip odometer stuck when it was about to roll over (like 299 to 300, or something like that) and the odometer stopped working. The speedometer worked fine, as did all other gauges. Only the odometer and trip odometer were not working. I thought I was going to have to get a new gauge cluster.
After stopping for gas, when I started the car again, the odometer was working. This happened intermittently about 10 times during a period of a few weeks, but would always start working again after turning the car off and restarting it. Then it stopped happening. It's been about a month now and it has been working fine.
I've also seen this same problem posted on the board, I think at least twice. I wonder if it's an age related problem with an electronic component that is just showing up on cars that are 5 years old. How many people have had this same problem? Is it always on a 96 Max?
Old Jul 5, 2001 | 02:30 PM
Whitemax's Avatar
Disco Biscuit
Well, I had to change out my speedometer, and it and the odometer are changed at the same time. My suggestion is to find one at a salvage yard, ( usually have to buy the whole cluster) and it will probably cost you around $100-$150. Find a GOOD mechanic that knows how to do this, and he can change the mileage to what your car has. I was charged $50 by mine. That way, I have no worries of Mileage fruad.
Old Jul 10, 2001 | 01:05 PM
BobK's Avatar
My odometer has been doing this off and on for the last year or so. In the past it seemed to fix itself after the letting the car set for a while, but now hasn't been working for a week or so. Read in another post that someone fixed theirs by replacing the ignition swith. Don't understand how the ignition switch would affect odometer.
As a side note I've found that this causes really poor gas milage.
Old Jul 11, 2001 | 04:08 AM
party_boy's Avatar
well
my "b" odometer (trip) went out once after a pothole. I went to the dealer to get an appointment (under warranty) and on the way back i hit another pothole and it started working. Its been about 70k since then and it sill works (Shrug)
Old Oct 29, 2001 | 09:42 PM
JLMaxima
Possible Purchase of instrument cluster
I would perhaps buy your working instrument cluster if the price is right. About how much would you want for it? Please reply back soon and let me know. Thanks a lot!
Old Oct 30, 2001 | 05:29 AM
amixam98's Avatar
Needs non-Maxima Friends
Re: Possible Purchase of instrument cluster
it took you three months to reply and you want someone to reply back to you soon?
Old Oct 30, 2001 | 09:20 AM
Rooster286's Avatar
heheheheeheheh
too funny.
Old Oct 30, 2001 | 09:26 AM
pocketrocket's Avatar
I had the same problem happen to me too.
When I first got my car end of July, my trip meter got stuck.
But I reset it, and it works fine now. So I am not tooooo worried
Old Oct 30, 2001 | 12:29 PM
JLMaxima
Have'nt driven the car!
Originally posted by Rooster286
heheheheeheheh
too funny.
Laugh all you want, my car has been garaged since September and I'm driving my work vehicle around. I am searching little by little for the best deal on a new/used odo. If anyone has one for sale please reply with the price and contact information. Thank You.
Old Oct 30, 2001 | 02:11 PM
sinewave's Avatar
The 95-96 odometers are gear driven. When you press the reset button you disengage the gear drive so that the numbers on the trip odometer can roll around to zero. Sometimes the gear drive gets stuck in the disengaged position. If pressing and releasing the button several times doesn't re-engage it, you may try a very light shot of CRC Electronics cleaner or WD-40. If you use WD-40, try and avoid getting any on the numbers or the gauge faces.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
Djsmaxima
Sep 14, 2015 11:58 PM
