Need Help Changing Battery
Old Jan 13, 2007 | 06:47 PM
pavan87's Avatar
My battery died in my 99 Maxima. I got a new one from AutoZone but I am having a problem when I try to install it. When I hook up the positive and negative terminals to the new battery, the alarm goes off. I tried to turn off the alarm with the remote but that doesn't work. I know the remote works because the doors lock and unlock. It continues to go off until I take off the connectors from the terminals. Is there a fuse or something I should pull before I change the battery?
2da mizzax's Avatar
key in door to disarm. then reprogram the remote.
Old Jan 13, 2007 | 06:54 PM
pavan87's Avatar
Do I leave the key in the door while changing the battery? How do I reprogram the remotes?
Old Jan 13, 2007 | 07:05 PM
2da mizzax's Avatar
no. change the battery and unlock the drivers door or trunk with the key. that should turn off the alarm. to reprogram the remote, put it in and out of the ignition 10 times. the lights will blink once. at that point turn the key to the "on" position. then hit the "unlock" button on the remote. I havent done this in a while so it may be 7 times in the ignition and the "lock" button but as soon as you see the light blink turn the ignition to "on" and hit either of those buttons. if the unlock doesnt work, try it again with the lock button.
Old Jan 13, 2007 | 07:38 PM
willard00's Avatar
should say in the manual how to reprogram it. i think there may even be a sticky too.
Old Jan 14, 2007 | 01:28 PM
supervinn's Avatar
if u had brought it from sams club. they would change for freeeeeeeeeeeeeee wooots Free ftfw
Old Jan 14, 2007 | 05:42 PM
Grand_hustle17's Avatar
probebly a short, somewhere
Old Jan 14, 2007 | 07:29 PM
MaximaSE96's Avatar
Maxima Owner
u shouldnt need to reprogram remotes.....i have never had too when i have changed batteries
Old Jan 15, 2007 | 05:13 AM
njmaxseltd's Avatar
Aftermarket alarm system? The OEM alarm doesn't act like that when a battery is replaced.
Old Jan 15, 2007 | 09:16 AM
f550maranello2's Avatar
u need to close the hood and close and lock all doors and unlock them with the key... i believe
Old Jan 15, 2007 | 09:29 AM
maximized98's Avatar
Addicted to the Org
you need to close the hood, scream out some naughty words, then go grab a cold one, try it again.
JoshG
51
Sep 21, 2015 10:41 PM
toyoking
Sep 16, 2015 07:05 AM
markevans999
Sep 10, 2015 04:29 PM
