Synthetic gear oil
Old Jan 15, 2007 | 09:54 AM
rockfordmaxII's Avatar
Synthetic gear oil
I have a 95 5 speed and i would like to put in synthetic trans fluid, should i just use any 75w90 synthetic?
Old Jan 15, 2007 | 10:42 AM
scrhale's Avatar
Many use Amsoil and Redline. Both we get for 7-8.50 with a group deal I believe.
Old Jan 15, 2007 | 11:22 AM
well, ive never done this before, so what is the easiest way to drain our trans fluid? is there a drain plug?
Old Jan 15, 2007 | 11:35 AM
Nealoc187's Avatar
SLOW
out the drain plug in the fill plug...
Old Jan 15, 2007 | 11:44 AM
MaximaSE96's Avatar
Maxima Owner
there are only couple synthetics that are safe to use...i know Redline MT-90 and one of the Amsoils which ever Amsoil is GL-4
Old Jan 15, 2007 | 11:50 AM
Bobo's Avatar
Quite frankly I couldn't be bothered with synthetic gear oil.
I had my transaxle gear oil replaced with Quaker State 75w90 GL4 at a Mr. Lube in February/05 at a cost of Cdn$34.19. That equates to less than US$30, which is less than the cost of a dino oil change with a crappy Fram filter at the same place.
Don't sweat the small stuff.
Old Jan 15, 2007 | 02:08 PM
so would mobil 1 75w90 be ok?
Old Jan 15, 2007 | 02:49 PM
dgeesaman's Avatar
Maintenance Monster
If you're going to go to the trouble of buying a synthetic, I would not use Mobil1. It says it should not be used in non-GL-5 trannys. Our tranny calls for GL-4.
I suggest Amsoil 75w-90 GL-4 or Redline MT-90.
Also be sure to use the actual drain bolt, not the black plastic gear position sensor. The sensor tends to crack.
Dave
Old Jan 15, 2007 | 02:55 PM
is the drain bolt the one that you need to use the 1/2 in. ratchet for? if so, i unscrewed it and nothing, i mean nothing came out.
Old Jan 15, 2007 | 02:58 PM
dgeesaman's Avatar
Maintenance Monster
The drain bolt is the one toward the rear of the tranny, facing the center? It's actually a 12mm bolt head. If you use a 1/2in wrench you could round it off and that really sucks.
The big bolt with the 12mm socket cap in the center, just below the battery is the fill plug. It should not drain any oil. When you refill, pour in here with the car level until the oil starts to overflow.
Dave
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
