misfiring
Old Jan 28, 2007 | 01:17 PM
huggs97max's Avatar
misfiring
If you are misfiring in a cylinder how do you know if it's the spark plug or the ignition coil?
Old Jan 28, 2007 | 02:03 PM
2da mizzax's Avatar
switch the ignition coil.
Old Jan 28, 2007 | 02:56 PM
matrix11229's Avatar
Switch ignition coil, and if you still get a misfire on that cylinder take the spark plug out and look if the ground electrode isn't bent.
Once I changed spark plugs and got a misfire. So I took the spark plug out and the ground electrode was bent all the way in so there was no gap at all.
I regap it and it's fine since then.
Old Feb 2, 2007 | 05:16 AM
VQ30DETT's Avatar
to check the coils, you want to ohm them out to make sure they are still good. check out the spark plug, when i had a miss fire it was cause by my fuel injector
Old Feb 2, 2007 | 06:46 PM
seanish4042
ur missing one huge possibility.
injector.
Old Feb 3, 2007 | 12:10 AM
rimrocka0834's Avatar
sorry to barge in on the thread but i also had a cylinder misfire on the max i just recently purchased...the guy said he had a tune up recently done where they changed the spark plugs. So im putting 2 and 2 together and was wondering if in fact they put bosch plugs in the car instead of NGK would that cause a misfire? If so is there a way to tell my looking at the plugs if they r bosch or not? Also it is true that bosch plugs r horrible for our maximas right?
Old Feb 3, 2007 | 03:55 AM
2da mizzax's Avatar
bosch = bad. the only way to tell is to take them out and look at the names on the plugs.
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
