Summer Project 97 SE
Old Feb 6, 2007 | 09:46 AM
Dodd's Avatar
So heres the situation. I have $5000 saved for upgrades for my Maxima this summer. She currently has 230,000 Km on her hasn't had a transmission rebuild or even problem but I'm sure one is due in the near future. After this winter its going to be my summer project car so no more winters . My question is, do you think that it would be better to do the 3.5 swap or Turbo/SC the beast? I'm not sure $5000 will cover everything I need for the turbo / SC. Ive looked at the sticky about doing the 3.5 swap and it says ill spend about $3000 doing it, so are there things that I should upgraded on the 3.5 engine before I throw it in with the other $1600 or should I upgraded my suspension, brakes all that stuff first? 3.5 or Turbo/SC that is the question lol. All opinions are welcome I need all the info I can get. (Maxima currently has CE y-pipe , Greddy SP2 cat-back, and Injen CAI.)
Thanks,
Jeff
Old Feb 6, 2007 | 09:51 AM
Max_Out's Avatar
Under the radar
I would go with the suspension and then the 3.5 swap... then maybe do a retro T/C on that, down the road of course. So yeah do the suspension and wheel set up and then the 3.5 swap. Just my .02
Old Feb 6, 2007 | 11:30 AM
max95q's Avatar
Suspension then Swap
Old Feb 6, 2007 | 12:29 PM
Dodd's Avatar
So how come the suspension then the swap? I can do them both at the same time cant I? or can i not get suspension for $1600.
Old Feb 6, 2007 | 01:16 PM
matts95max's Avatar
please dont spend that much on struts/springs or coilovers! thats rediculous if you ask me, even if you have the money! you can get a really good strut/spring set up for at most $600. You can get the swap done(if you are doing it yourself for anywhere between $1200 I think was the lowest I saw and i'd say 2g's) So for $3500 you can do suspension and motor swap. save the other $1500 for when something breaks. If it were me, I would not spend it all. I just did a de-k swap for like $1100 I think, and spent another $700 fixing my tranny and getting a new axle. Spend your money wisely!
Old Feb 6, 2007 | 01:17 PM
matts95max's Avatar
spend some time in the all motor and suspension forums..ok a lot of time reading up on this stuff.
Old Feb 6, 2007 | 01:43 PM
ewuzh's Avatar
With an extra $5000 lying around, I would consider selling the max and buying something else. But assuming, you're keeping the maxima:
Suspension upgrade is less than $1000 (coilovers (or GC/Koni), strut bars, and rear sway bar).
VQ35 swap is less than $1200 if you do it yourself. Use the rest for a transmission rebuild with Quaife LSD (rare gem is on its last production run, check group deal forum).
Old Feb 6, 2007 | 02:23 PM
VQ30DETT's Avatar
3.5 swap, and get some suspenison upgrade
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Forge277
Jun 13, 2016 09:26 PM
