Battery or Alternator?
Old Feb 8, 2007 | 08:50 AM
1Phat Max's Avatar
I work 3 miles away from home and yes'day the weirdest thing happened. I left work and the car started up fine and was driving okay, I stopped for gas and turned off the car. It wouldnt start up again. I had to have it jump started and drove home. After come home, i let the car sit for about 20 min and tried to start it and it started up fine. Today morning, it wouldnt start again. I just replaced the battery 2 months ago so dont think it can be that. You guys think alternator is not charging the battery enough? Or is it 'cuz my drive is too short for battery to get charged fully?
Old Feb 8, 2007 | 09:07 AM
ethnic6's Avatar
most likely it is the alternator, seems like its draining ur battery... get it changed
Old Feb 8, 2007 | 09:12 AM
willard00's Avatar
batteries start the car, alternators keep it running(charge battery). my guess is that something is staying on and draining your battery. could also be bad connections or a bad ground. check the ground on block, my roomates car has this same problem, he changed the alternator and it didnt fix anything cause the car still wont start with a jump. he then checked the ground on the block and it was covered in oil.
Gismo-T's Avatar
B!tch We Got a Problem
What year is your MAX?
Could be one in the recall....call up Nissan & give them your Vin # to see if it's one of them.
Old Feb 8, 2007 | 09:23 AM
1Phat Max's Avatar
Year of max is 95 and have 93k miles. Where do i check the ground or where is block located?
Old Feb 8, 2007 | 09:26 AM
Gismo-T's Avatar
Not included in the recall....
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
