stock fog light bracket
Old Feb 9, 2007 | 08:13 PM
zeeman's Avatar
Hey guys, i have a 96 gle and i m thinking about putting in stock fog light bracket thru my bumper area after i cut the piece out. What i have gather thru search is that the bracket should bolt up to my bumper beam with the holes for the screws already there. Is this the case??
Oh and any hints to how i could make a clean cut of my fog light opening? I m thinking using a dremel and then sand paper the edge, but would the dremel be too rough and roughen up my opening?
Old Feb 9, 2007 | 08:23 PM
jitiola's Avatar
use a dremel that what my friend did when we did mine i have a 96 gle also. after you cut the holes out there will be holes already there for for the screws. so just line it up and screw it in
jltibbs's Avatar
i used a dremel on mine. no sandpaper, no probs. they will bolt right up. plus, if you get the whole kit from nissan, it comes with a new turn signal switch. you will have the plugs for the foglights under there as well
before
after
Old Feb 9, 2007 | 09:53 PM
jitiola's Avatar
here's pics of mine
[http://i32.photobucket.com/albums/d5...upclsejosh.jpg
Old Feb 10, 2007 | 09:44 AM
zeeman's Avatar
cool, thnks for the info
Old Feb 13, 2007 | 05:32 PM
adawg624's Avatar
i have a 99 gle, and the fog light holes have pieces running horizontally through the empty space. What's the best way to remove these?
Old Feb 13, 2007 | 08:15 PM
jitiola's Avatar
same way, but you could probably just use a utility knife since your holes are more tucked away
Old Feb 14, 2007 | 06:33 AM
maximabebe's Avatar
If you need a set of brackets I have a pair laying around from a 99.
Old Feb 14, 2007 | 10:38 AM
zeeman's Avatar
IS there a template i can get from nissan dealers to help me cut the fog opening?
Old Feb 14, 2007 | 04:36 PM
BalistiX18's Avatar
Yea i wanna get some fogs for my 97....Is there a thread telling you how to wire them correctly
Old Feb 14, 2007 | 05:56 PM
ChrisD's Avatar
You have a PM.
Old Feb 17, 2007 | 12:22 PM
maxima_tuned's Avatar
Can anyone tell me how to change the bulbs???
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
