Vibration doesnt stop!
Old Feb 12, 2007 | 11:46 AM
Stillen Maxima's Avatar
Pay to Play
Let me give this a try for the last time. Ive had a vibrating issue on my max for quite some time now. Ive searched, read and am not shure what the problem could be. When im going 65mph the car is perfect, Im getting to 70 the steering wheel starts to shake, 75 the car is anoying, 80 it goes away. I have replaced the tires, New toyo proxes 4, new rotors, fresh balance, alignmet is not the issue. I took it to a shop to get an alignment and the guy told me that there was no need to, that the alignemt was fine. Im getting ready to chance my clutch and other things on the car and while im at it, I would really appreciate if anyone of you could tell me what is causing this.
Thanks for your help
Albert
Old Feb 12, 2007 | 02:46 PM
btvenom's Avatar
it could be one of the ball bearings on the joints?, I've always had some little vibrations in mine through my steering wheel that changes with speed. One time my steering wheel actually the lever to move it up and down was a little loose and the steering wheel vibrated for some reason, check to make sure that's tight.
Old Feb 12, 2007 | 03:09 PM
Pay to Play
Well thats a start. Im gonna check that too
Old Feb 12, 2007 | 03:10 PM
Pay to Play
Any other suggestions?
Old Feb 12, 2007 | 04:45 PM
maximaSE327's Avatar
check anything rotational... i have the same problem, i keep replacing everything that is bad and it gets a lil better but isnt completely gone... well start from simple to hardest... tire balance, alignment, warped rotors, loose ball joints or tie rods (inner or tie rod ends), bent axle/ bad CV joint, wheel bearings... there are a lot of moving/ rotation parts and any one could cause a vibration... hope i helped a lil
Old Feb 12, 2007 | 05:02 PM
Ceasars Chariot's Avatar
Old Maxima Legend
+1 on post #5, go to the best tire shop you know of, im lucky i have one here in my area. check your tires, then have them balanced and an alignment.
let them test drive. if its still there then keep moving forward until you find the whats causing it.
Old Feb 12, 2007 | 05:16 PM
kbmaxima's Avatar
i've changed everything in post #5. end result, it was the steering rack. look into that before anything else
Old Feb 13, 2007 | 10:33 AM
Pay to Play
Thanks, steering rack it is. I guess your the only one who read what i wrote on post#1. I already did just about everything. Im gonna check it out.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
