how does dealer find sticking calipers
Old Feb 15, 2007 | 12:53 PM
edwardh1's Avatar
How does the mechanic at the dealer find a sticking caliper?
rotate wheel by hand and compare sides??
Some other way?
Old Feb 15, 2007 | 01:12 PM
maximabebe's Avatar
Some other way?
Perhaps depress the brake pedal to verify that the pistons move?
Old Feb 15, 2007 | 01:23 PM
RA030726's Avatar
I'm nutty for Nissans
pad and rotor wear
Old Feb 15, 2007 | 01:55 PM
pmohr's Avatar
No more Maximas...
Originally Posted by JSutter
pad and rotor wear
Or I'd take it for a light drive then check the temp of each caliper.
Old Feb 15, 2007 | 03:18 PM
Scruit's Avatar
U wanna try me young boy?
Drive it about a mile at low speeds, <30mph, the feel the temp of the wheels. Sticking caliper=hot wheel.
Don't reach through and touch the rotor... sticking wheel+touching rotor = huge badass blister on fingertip.
Old Feb 15, 2007 | 06:31 PM
LASTONE's Avatar
Depends on how bad it is stuck. If it is bad it will be noticable right away the rotor will have hot spots on them blue and gold. If them pad is worn more on one side than the other. I seen the wheel lock up completely and be towed in.
Old Feb 15, 2007 | 06:47 PM
DanNY's Avatar
Ad·min·is·tra·tor
yup...the rotor that's blue and grooved is your busted caliper. basically look for the rotor that's worse than the other ones.
Old Feb 15, 2007 | 07:34 PM
padam07's Avatar
I just did that last year. Whoops. A blister about 3/8 of an inch long. I don't even know why I did it. I knew that caliper was sticking already.
Old Feb 16, 2007 | 11:11 AM
edwardh1's Avatar
no it was a serious question as in your rotors warp - how do you rule out that a caliper piston sticks just a little and heats up the rotor?
does the mechanic turn the tires manually and compare?
Old Feb 16, 2007 | 11:16 AM
mindlessoath's Avatar
my piston was hard to push in, really really hard, its not suppose to be, so i would say thats how to test it.
maxfanfromohio's Avatar
Shiver me timbers.
These were serious responses. That is how a mechanic will check.
Old Feb 16, 2007 | 07:40 PM
ImmaSquashYou's Avatar
heh, you thought these guys were joking......but we're really serious.....i guess it sounds kinda funny......but its true
Old Feb 16, 2007 | 11:27 PM
swatspyder's Avatar
Gotcha!
My story: I had purchased my Max from South Tacoma Honda out in Tacoma, WA. Well under warranty I had them replace the brakes since the car had horrible breaking. So they do w/e and end up turning the rotors and cleaning the pads and throw it back together.
Well I get about 4 miles towards my house and the whole way I'm smelling this nasty burning rubber type smell and I'm thinking its this car I had been tailing the whole way. So I get to a stop light and happen to look back and all I see is white smoke coming out of my rear driver side tire well. Anyways, I call up the Honda dealership and they tow it back, all this while i'm pissed off and glad the thing wasn't on fire. So they resurface that rotor and replace all of the pads with new ones and I finally get it back a day late.
Question though. When I finally end up putting on the brembo rotors and hawk pads, should I replace the calipers with new performance ones, new oem ones or keep the ones I have?
MaxLife17
Jun 27, 2019 01:37 PM
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
mikebla
Sep 3, 2015 05:37 PM
crazyespn
Sep 3, 2015 01:30 PM
