00vi
Old Feb 18, 2007 | 01:10 PM
Grand_hustle17's Avatar
00vi
does anyone has the 2000 intake manifold on there 4th gen? how much did it helped at top end? can you tell the difference with the way you car drives, sound and feels???
Old Feb 18, 2007 | 01:29 PM
bigpulve+'s Avatar
A lot of people have the 00VI on there cars. It helps with the top end without killing the mid or low end like the MEVI does. You will feel a difference in the way the car drives. You will be looking at about 30ish crank HP when done.
Old Feb 18, 2007 | 01:43 PM
man that sounds excellent, wound it also sound different?
Old Feb 18, 2007 | 02:18 PM
Tatanko's Avatar
Bacon Lover
For the most part, no, it doesn't sound any different. The advantage isn't simply top end, either, it smooths out the entire existing low and mid range as well. Easily the best NA mod there is, and I love mine.
The question is...are you mechanically apt? If not, don't even think about it.
Old Feb 18, 2007 | 02:26 PM
i cant do it but my boy knows how to and he knows a couple of the feallas that worked at redline max so putting it on isnt the problem, i get 98% of my upgrades professionally done, ill spend the money on my car no problem but thanks for letting me know
Old Feb 18, 2007 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
30ish crank hp =
MEVI's give 38-42 @ the wheels @ 6500 RPM. So the 00vi will give at least that.
Old Feb 18, 2007 | 03:28 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by NmexMAX
30ish crank hp =
Shh. Don't say that. The noobs are impressionable little people, they'll take you seriously
Old Feb 18, 2007 | 03:44 PM
thats great to know guys but lets not make fun of newbies we were all there once, i thought this was a friendly forum, and really and truely, all newbie jokes i heard so far kinda sucks. i gotta get that manifold ASAP, i was planning on doing it tomorro but here comes the snow (hard)
Old Feb 18, 2007 | 03:48 PM
NmexMAX's Avatar
dot dot dot ...
I'd rather call a newbie out than have them spread false information.
Check the AM forum, there are lots of threads to help you out.
Old Feb 18, 2007 | 03:56 PM
ethnic6's Avatar
thank god I know MaximaSE96 lol... I am NOT mechanically apt
how about not callin anybody out
Old Feb 18, 2007 | 04:13 PM
shiftnatredline's Avatar
Godzilla
yeah so i'm looking for one of these too now..
Old Feb 18, 2007 | 04:15 PM
NmexMAX's Avatar
dot dot dot ...
Very well, carry on.
Old Feb 18, 2007 | 04:20 PM
995SPDSE's Avatar
Tatanko Would U B Intrested In Doing 00vi Swap On A 99se
Old Feb 18, 2007 | 04:37 PM
Wassup2114's Avatar
Just so you know, you'll be needing a lot more than simply the 2000 IM.
Old Feb 18, 2007 | 04:58 PM
bigpulve+'s Avatar
30ish crank hp =
I was giving a rough estimate.
Old Feb 18, 2007 | 05:36 PM
Cdg2125's Avatar
I'm surprised that he asked if anyone had it on their car....one of the fastest growing mods now-a-days
Old Feb 18, 2007 | 06:20 PM
grey99max's Avatar
LandShark has Cosworth
Wow - I'm glad my MEVI doesn't have a "killed mid or low end"
Old Feb 18, 2007 | 06:28 PM
4x4Max's Avatar
I dunno bout that, it seemed like a pretty straightforeward mod once some simple things got figured out, i wouldnt have any troubles with mine if i wasnt a cheap *** and didn't re-use stock gaskets....not completely bolt-on, but hard? naaaahhhh...
to o/p, keep in mind that i used the 5th gen lower so the upper bolted right up on it withotu any drilling.
Old Feb 18, 2007 | 06:47 PM
Cdg2125's Avatar
If you're not at all mechanically apt then you will kill the car. I'm sure you knew enough about working on the car. I think its more about actually knowing how to work on cars in general thats necessary.
Old Feb 18, 2007 | 06:49 PM
speed racer's Avatar
Hey Grand Hustle. Even though you may not be doing the work, it might be a good idea to search through the all motor forum for old 00VI threads. Your going to have to know what setup to get and this can easily be accomplished through the search engine on the all motor forum.
Old Feb 18, 2007 | 06:56 PM
ghostmax301's Avatar
Just finished my swap. it was the "eccs2" fuse in the box beside the battery.. car is running. Now to address the idle issues... Free Search, here i come to PWN j0o!!!
BTW, i most likely will be doing his (Grand hustle) swap
Old Feb 18, 2007 | 08:15 PM
frisballs17's Avatar
how much for a 00vi, time for labor, parts list, difficulty and so on. and if there is a sticky would someone kindly redirect me to it!
Old Feb 18, 2007 | 08:23 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Start here..
http://forums.maxima.org/search.php?searchid=543416
Old Feb 20, 2007 | 02:26 PM
Bags's Avatar
BUMP.. I suck at the links...
Well that does not help you worth a **** then HUH??
My bad... try these....
http://forums.maxima.org/search.php?searchid=544020
That should be the search link to about 4 pgs
http://forums.maxima.org/showthread....highlight=00vi
more info
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
