Price of New Maf Sensor...
Old Feb 23, 2007 | 03:52 PM
JWoodstock0617's Avatar
Hey guys...
So after about a minute of driving the other day, when I hit the gas, the car surged once or twice, and the Check Engine light came on. When I took it to AutoZone I got the code P0100 a few times. So, I have a few questions:
A) Is it most likely the MAF sensor that is no good? Or could it be more of a vacuum problem?
B) If it is the MAF sensor, how much do they run for the 4th Gen (I have a 97 GLE). I called Nissan, they said it was $550, and then when I called the auto parts store down the street (a legit place), they said it was $248. Do you think the quality of the products are the same? Or should I just go with the Nissan MAF....or....can I just go to a junkyard and pick up an old MAF and throw it in?
I have a K&N CAI in, and supposedly all aftermarket airfilters burn up the MAF. Let me know what you guys think.
Joe
Old Feb 23, 2007 | 04:16 PM
LiGhtSoUt's Avatar
you can get one from the junkyard if you can find one and no cai's do not burn the maf's if that was the case no1 would have them
Old Feb 23, 2007 | 04:19 PM
NmexMAX's Avatar
dot dot dot ...
Why don't you verify is wrong.
Old Feb 23, 2007 | 04:24 PM
CAI's do burn out MAF's in some cases. If they didn't, there wouldn't be a poll on here asking if your CAI ruined your MAF.
http://forums.maxima.org/showthread.php?threadid=122198
Check it out.
Old Feb 23, 2007 | 04:25 PM
MDeezy's Avatar
Check it out.
since when did polls automatically make something true
Old Feb 23, 2007 | 04:26 PM
http://forums.maxima.org/showthread.php?threadid=122202
wrong site sorry
here is the new one
Old Feb 23, 2007 | 04:27 PM
never, but do you think it is it a coincidence that more people's MAF Sensors die when they have CAI?
Old Feb 23, 2007 | 04:28 PM
NmexMAX's Avatar
dot dot dot ...
We're back on this subject again
MDeezy's Avatar
it seems like there was a lot of user error more than maf error. You over oil a the filter thats not good if its an aftermarket intake or stock.
but if thats what you believe then dont use an aftermarket intake.
Old Feb 23, 2007 | 04:32 PM
alright, well my car is running pretty smoothly, i've only felt this surge a few times. i go to school in the middle of nowhere in VA, and will be driving it home to NY to see my mechanic in May. should i get it checked out asap here? or will be ok to keep it as is until i get home in May
Old Feb 23, 2007 | 04:37 PM
NmexMAX's Avatar
dot dot dot ...
Why don't you check the code yourself
Old Feb 23, 2007 | 05:48 PM
well, i checked the codes, it came up P0100, which is something with the circuit board of the MAF Sensor...how can i tell if it is a vacuum leak or if the MAF Sensor is bad?
Old Feb 23, 2007 | 05:52 PM
XAugusta MoonX's Avatar
Voltmeter. Check the resistance on the MAF. If it's not within specs, replace it.
Old Feb 23, 2007 | 05:54 PM
NmexMAX's Avatar
dot dot dot ...
Your MAF sensor is bad.
www.car-part.com
Air Flow Meter.
Old Feb 24, 2007 | 07:42 PM
thanks guys i'll hook up a voltmeter to it tomorrow...
i appreciate all the help
Old Feb 24, 2007 | 07:53 PM
2da mizzax's Avatar
vacuum leak wont really be detectable by a smoke test. best way is to listen. If you are getting a MAF new, let me know and I can save you $100 or so off of the dealer price. junkyard or partout will definately be your best bet though. Dont know what you mean by CAI "burning up" mass air flow sensors, but there could be a chance of oil contamination if you oiled yours too much. perhaps the first thing you should do is spray it down thoroughly with some CRC MAF Sensor cleaner (not the electronics cleaner or any other spray). maybe you can find someone to loan ou their MAF for 30 minutes to see if that is indeed the problem.
Old Feb 24, 2007 | 09:31 PM
RA030726's Avatar
I'm nutty for Nissans
Check it out.
5th gen = moot point, were in the 4th gen section. The 4th gen MAF is a tough MAF, 5th gen MAFs are crap.
Old Feb 25, 2007 | 11:40 AM
NmexMAX's Avatar
dot dot dot ...
My A32 maf went @ 218k.
I carry a spare MAF for my A33B..
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
jc53
Oct 6, 2015 06:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
