New rotors and brakepads.... verrry weak
Old Jul 6, 2001 | 11:28 PM
hlh0501's Avatar
OK, I put on stillen cross drilled on the front, and axxis pads all the way around today..
broke them in from what I knew, correctly (can anyone post the correct procedure for doing the breakin?)
now the problem is, as soon as I put them in and set my car back down, the brake pedal has to be pushed in WAY far before they work... and they dont seem to work very well. Did I do something wrong? Do they need more breakin time?
I compressed the pistons to make them fit over the pads, and had to drain a tad of brake fluid too but its up to the MAX line... ? I almost went off the road tonight b/c I came to a T and couldnt stop fast enough, so I need a solution.. THANKS!
Old Jul 6, 2001 | 11:40 PM
Nealoc187's Avatar
SLOW
What sort of break-in method did you use? For how long? Did you clean the rotors with gasoline or some other solvent to get that anti-corrosion goo off of them (I assume thats anti-corrosion stuff on there anyways. But you are supposed to get it off regardless.)
Old Jul 7, 2001 | 12:05 AM
Chunger's Avatar
My other car is a Hybrid
I don't get it? What do you mean 'after you put them in and set your car down' after break in?
Breaking them in basically means to take it easy on the brakes for the initial couple of hundred miles... I know there are formal ways but that is basically it.
If you need to push the pedal WAY down then you either have some contamination on the friction surface and pad... or you have air in your brake lines.
Baer Racing have some 'bedding' instructions which are similar and informative... LINK
Old Jul 7, 2001 | 07:36 AM
Ravq's Avatar
Definitely rebleed them!
Old Jul 7, 2001 | 08:26 AM
redmaxpa007's Avatar
i SeE what you did therE
i just installed the same thing last weekend... didn't have any problems...
initially the breaks were weak till the gold was rubbed off, but now they are great.!!!
Old Jul 7, 2001 | 09:06 AM
hlh0501's Avatar
stupid question....
how do I bleed my lines, b/c my guess is I do have air in them....
I am a big mechanic as you can now tell...
Old Jul 7, 2001 | 10:54 AM
Daniel B. Martin's Avatar
Spongy or low pedal?
Is your pedal low or is it spongy? This is an important distinction.
The principal symptom of air in the lines is a spongy pedal, not a low pedal. A normal pad replacement job does not involve opening the hydraulic system, so you would not expect to get air in the lines.
Old Jul 7, 2001 | 09:35 PM
hlh0501's Avatar
Re: Spongy or low pedal?
What is sprongy? I attempted to bleed my lines today.. I took all the rims off, and went from left rear, to right r, to left f, to right front.. on each one I pumped the brakes 6-12 times till it was hard and held down on the last pump, while a friend opened the lines, let the fluid squirt out, then close it back... I did it 3 times on each back tire, and 4 on each front... put the rims back on, it was a little better... not too much though.
My pedal, I have to push about 1-2 to 2/3 way down before I get any braking power... then once its like almost all the way down it brakes normal... I cant ever get them too hook up REALLLLL good like slamming them on (I almost wrecked, well, went off the road b/c of that)
oh well, I am about to last resort take it to the house.. oh I mean $hop ahh
Old Jul 8, 2001 | 07:37 AM
Re: Re: Spongy or low pedal?
What is sprongy? ...
The normal brake pedal "feel" is this: you can press the pedal down a certain distance, usually one-third of its total travel, and hit a point of rock-hard resistance. Once you hit that point, you can double or triple the force applied to the pedal and it won't move down any further. In contrast, a "spongy" pedal doesn't have any point of rock-hard resistance. As you press the pedal down you will feel some resistance and if you press harder the pedal goes down further with more resistance. It feels as if you were stepping on a sponge, hence the descriptive term "spongy".
A "spongy" brake pedal is almost always caused by air in the hydraulic lines. Your description suggests that you bled the brakes correctly. Something is wrong with your brake system.
In your initial post to this thread you said you installed new front rotors. Did you compare the thickness of the new rotors with the old ones? They should have been about the same.
Old Jul 8, 2001 | 07:48 AM
deezo's Avatar
My experience with the crossed drilled rotors is that you should be easy on them for 350 miles. If you're driving faster than 35 miles per hour during break-in, you are looking for an accident. Take your time and break them in. Mine are fine and you shouldn't have had to bleed the lines.
Old Jul 8, 2001 | 10:11 AM
NickStam's Avatar
Get a shop manual They help alot.
Apr 16, 2020 05:15 AM
spencerwh1
Jun 30, 2016 05:44 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
