My cv joint is broken what are my options and how dangerous is it (for my car)
Old Feb 26, 2007 | 10:28 AM
Luisjo's Avatar
So i have an oil leak mystery and today i was analyzing and found that my cv joint is broken (front passenger) so my question is is it dangerous? what problems can it cause? please answer so i can change it asap. here are some pics if they don't help much i will put other ones by 4:30 since i have to go to the university
Old Feb 26, 2007 | 10:33 AM
mikey chalupa's Avatar
It's pretty bad and dangerous. Both are broken on mine and I get a loud popping noise whenever I turn in either direction. I am replacing both this weekend if the weather is ok.
I have been riding around like this for about 4 months now. I wouldn't recommend it though. I messes up braking also.
Old Feb 26, 2007 | 11:08 AM
LASTONE's Avatar
looks like your steering rack boot to me not your c.v joints. can't tell that well in the pic.
Old Feb 26, 2007 | 11:11 AM
LASTONE's Avatar
also is your tire in the wrong direction?
Old Feb 26, 2007 | 12:00 PM
Fr33way™'s Avatar
Wild for Width
That is power steering fluid and yes, the tire is on backwards.
Old Feb 26, 2007 | 12:08 PM
Luisjo's Avatar
about the tire..... didn't noticed.. also if not the cv joint then what is it??
Old Feb 26, 2007 | 12:12 PM
Fr33way™'s Avatar
Wild for Width
Part of the steering rack, the boot for sure is gone.
Old Feb 26, 2007 | 12:18 PM
Luisjo's Avatar
so i will take it to a mechanic and say is the steering rack boot.. also when i turn either side i dont hear any clicks or anything like it, i do have a problem that when i accelerate slowly (at about 900-1200) rpms theres a chirping-vibrating sound, is there anyway the 3 are related (sound, leak, broken boot)?
Old Feb 26, 2007 | 06:22 PM
Fr33way™'s Avatar
Wild for Width
Given the vague description, I could only be sure that the leak and boot are related at this time.
Just so you know, that is the inner tie-rod boot.
Old Feb 26, 2007 | 06:48 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
That is the stearing rack boot, but Ive never seen oil leak out of there. Your stearing rack would have ot be really screwed up to leak power stearing fluid out of there.
Old Feb 26, 2007 | 06:52 PM
kcryan's Avatar
well... whatever it is...if it is a CV, when you replace it, you have only one option. Raxles.com Dont **** around with cheap ones, i did that, changed it again 9 months later, just get the good ones from the start and be done with it
Old Feb 26, 2007 | 07:07 PM
LASTONE's Avatar
the leak is due to the boot being torn sand and grit get in there and wear the seal out the it leaks.
Old Feb 27, 2007 | 03:01 AM
dgeesaman's Avatar
Maintenance Monster
Yep, in case this wasn't made clear, if you're leaking from the power steering rack boot, your mechanic won't be talking about rubber boots. He'll be talking about a whole new power steering rack. Leaks like that mean a shot steering rack.
Dave
Old Feb 27, 2007 | 06:12 AM
ZaxWhite97Max's Avatar
I bet your tires stick like hell
Old Feb 27, 2007 | 10:38 AM
Flava_24/7's Avatar
Boosted Panda
Dave
Yup, and its not a fun job.
Old Feb 27, 2007 | 11:11 AM
Gismo-T's Avatar
B!tch We Got a Problem
Replace your CV shafts......swaybar bushing looks worn.....change teh
swaybar endlinks (that's where you get a popping noise).....switch wheels around.
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
classymax420
Aug 6, 2015 06:35 PM
