fried ECU
Old Feb 27, 2007 | 11:42 AM
Riot^'s Avatar
fried ECU
so, I'm faced with a task of getting a new ECU for a 98 5spd.
Is an Auto and 5spd ECU compatible?
I don't think I want the one from the dealer, they said it may be as much as $1000.
by the way, how I fried the ECU, I have no idea.
Old Feb 27, 2007 | 11:46 AM
MDeezy's Avatar
it will be cheap at a junkyard
check car-part.com
auto ecu will work on an 5spd
5spd ecu wont work on an Auto.
best bet is to match the year and transmission type for your car.
Old Feb 27, 2007 | 11:59 AM
Riot^'s Avatar
ok, I gotta look into that.
I got an offer for an Auto ECU from 98Max, same as mine, for $150CA.
Hope you're right, the Auto will work on 5spd.
Old Feb 27, 2007 | 12:03 PM
MDeezy's Avatar
it will but you'll throw a code. but the code will be related to the Auto tranny that isnt present. I think you idle might be a little higher, but other than that will fuction normally.
I'd still suggest trying to find a MT ecu rather than a AT one, especially if you cant have codes for emissions.
Old Feb 27, 2007 | 12:10 PM
Riot^'s Avatar
I'm in Toronto, so I'm not sure what the standards are here for something like this, but you're right, I'll keep looking for an MT.
Thanks so much!
Anything aftermarket worth looking into?
nismology's Avatar
What makes you think it's fried?
Old Feb 27, 2007 | 12:13 PM
Riot^'s Avatar
the dealer diagnosed it as fried.
It doesn't give off codes when checked manually with a screw, nor can a dealer computer read it. It's as if it's just not there.
The dealer mechanic was a friend so there is no "screw me over" business there.
I was also told by someone that the ECU is vehicle serial number specific.
How the hell does that work?
Old Feb 27, 2007 | 12:30 PM
99BlackMaxMS's Avatar
Is the car running poorly or any noticable changes?
Old Feb 27, 2007 | 12:31 PM
nismology's Avatar
Old Feb 27, 2007 | 12:37 PM
andrei3333's Avatar
Here in Toronto as far as i know t omy limited emissions Knowledge, the all three 02 sensors on our cars must be functioning properly to get a good emission rating and pass it.
Old Feb 27, 2007 | 12:52 PM
MDeezy's Avatar
did you check the ecu screw, maybe it isnt in the proper position. there was a TSB for 95/96 ecu's but thats it.
Old Feb 27, 2007 | 12:58 PM
Riot^'s Avatar
Nismo, that's EXACTLY All my symptoms!!!
I'm pretty sure the ECU is done, what the heck else could it be, if NO ONE can read it.
Old Feb 27, 2007 | 02:09 PM
Riot^'s Avatar
do you know if Any ECU from my year will fit?
Dealer said there are about 20 available, by month of manyfacture, blahblahblah
does that all really matter as long as it's a 98SE 5spd.??
Old Feb 27, 2007 | 02:14 PM
I would just try and get a 98 5spd ECU. If you can try and get the month of manufacure of the car that it came out of.
Old Feb 27, 2007 | 02:22 PM
urmab's Avatar
I have 97 MT ecu it should work with a problem on a 98 if you want it ill sell it to you.
Also yes any year will fit but if you go with 95-96 you will have a code for rear O2 sensor since the pin in in different place. I personally have a '95 mt in my '98 mt, Still have no problems with it.
Old Feb 27, 2007 | 02:37 PM
Source's Avatar
i need to know if i can install the 6spd transmission and which car 6spd transmission i can install in my 5spd
Old Feb 27, 2007 | 02:41 PM
nismology's Avatar
Why are you hijacking the man's thread?
Old Feb 27, 2007 | 03:11 PM
RA030726's Avatar
I'm nutty for Nissans
Dont mess with other years, you will more than likely get a CEL forcing you to chase down certain emissions related components. Keep in mind build dates on 98's start in 97 so double check years.
Old Feb 27, 2007 | 03:22 PM
MDeezy's Avatar
i agree. try your best to keep it to your year.
production date is located on the body of the car... how to explain, when your sitting in the driver seat. if you open your driver side door, and look there. you'll see the white sticker with the info.
Old Feb 27, 2007 | 03:38 PM
Blackwind's Avatar
Toronto California, or Toronto Canada? the CA is throwing me off.
Old Feb 27, 2007 | 03:44 PM
Riot^'s Avatar
That's Toronto, Canada
and thanks to ALL for the replies, I really want to save some $$$ by not buying from a dealer.
Car still running in safe mode, but I don't want to drive it like that.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
