Vibration while driving
It doesn't vibrate while I am parked or at extremely slow speeds. I shrugged it off at high speeds because I thought it was the alignment, but I got it aligned back in October. The car still slightly drifts but nothing crazy. I tried to ignore it, but it has gotten progressively worse. I was on the highway today doing 60 give or take, and I felt my car was going to shake apart. I notice a slight tick in my steering wheel whenever my makes a whole spin. I also hear a "dub, dub, dub" sound and it gets faster or slower according to how fast I am going. I recently also noticed a bubble in my tire that I got plugged. Another thing I notice or hear rather is I hear a click from my right front tire whenever I turn my wheel all the way to the right. I want to say that I just need new tires, but before I invest in that I wanted to see what you guys thought.
Tires are cool, as far as the treads go. Dunno what the torque on the lugs is, I tighten them up by hand but they seem tight as hell.
Could it be my bearings? I recently replaced one axle, control arms, tie rods, all of that crap. Haven't jacked it up to see it the cv boot is torn, but I doubt it.
i get a vibration when im going 70+MPH....but thats cause im going 70+MPH....lol and cause its front wheel drive. the bubble in your tire it no good. i had one in my sidewall, had to replace the tire. and its normal for the car to pull a little bit due to concave of the road.
Racer, its possible that a belt is damaged in your tire, causing the vibration. I had experienced this 4 years ago after hitting a large pothole at night. New tires solved it.
As far as the noise that is heard when the wheel is turned all the way to the right....possibilities are that it is a bad strut bearing. The bearing doesnt turn properly, causing some resistance and a faint thud can be heard. If your struts themselves are shot, they will cause teh car to stray on the highway. How many miles on your Max? Has any front end parts been replaced?
Well I have it in the shop today...perfect time for it to conk out on me. I have to drive like 300 miles this weekend and i'm in the middle of a bunch of exams at school so i cant really check it out myself.
I replaced alot of crap on the front end, new struts (kyb gr-2s, although i regret getting them), control arms, tie rods, i hit a curb back in october and had all of that replaced and got it aligned.
and are u lowered ?
maybe I need new tires
Check your rotors they're probably warped. At slower speeds like 30-35mph,
there will be a continuous thump. It fades away at higher speeds, but it's a fast thump.
WARPED ROTORS
WARPED ROTORS
WARPED ROTORS
WARPED ROTORS
Tires are definately a possibility. I was having really bad shakin at 70+ miles per hour with my old set. Once I upgraded to my new 18's and put on some new tires, no shaking whatsoever. Even at 100mph+ it was still silky smooth.
Mar 12, 2020 12:06 AM
