Did foglight rewire and headlights come on with parking lights
Old Mar 3, 2007 | 12:39 PM
Mxrider52's Avatar
I support for what?
Alright so I just did the foglight rewire and now when I turn on the parking lights the headlights also come on. Everything works like it should with the fogs. The one thing I didnt do was cut the green/yellow wire in the fuse box I just spliced into the wire. I am now thinking that is what my problem is since I didnt actually cut the wire in two which is causing the headlights to come on with the parking lights. Anyone know? Thanks
Old Mar 3, 2007 | 12:56 PM
jltibbs's Avatar
click here homie
Old Mar 3, 2007 | 12:58 PM
Mxrider52's Avatar
I support for what?
Ive already read that and all. I just want to know do I need to actually cut the green/yellow wire to not make the headlights come on with the parking lights?
Old Mar 3, 2007 | 01:01 PM
jltibbs's Avatar
You will need to find the trigger line for the fog lights (it should be green with a yellow stripe) Cut this wire. Tape off the wire leading down with electrical tape so that it doesn't short on anything. Strip back the wire going up into the relay. Now take 3-4 inches of thick insulated wire (at least as thick as the g/y foglight trigger, and 'connect' one end to the g/y stripe fog trigger going into the relay.
read more
Old Mar 3, 2007 | 01:04 PM
Mxrider52's Avatar
I support for what?
I read where it said cut it but I just tapped it thinking it would do the same thing. So I need to actually cut the wire then? Alright going to cut the wire right now then.
Old Mar 3, 2007 | 01:07 PM
jltibbs's Avatar
you have seen the light brother. hopfully just the foglight and not your headlights too
Old Mar 3, 2007 | 01:10 PM
Mxrider52's Avatar
I support for what?
What is this suppose to mean?
Old Mar 3, 2007 | 01:12 PM
jltibbs's Avatar
i was just saying once you finish the setup you will only see your foglights, unless your headlights are on too. didn't mean to offend.
Old Mar 3, 2007 | 01:29 PM
Mxrider52's Avatar
I support for what?
Well cut the wire and I am done. Foglights now come on with the parking lights and the headlights stay off like they should.
Old Mar 3, 2007 | 02:11 PM
jltibbs's Avatar
awesome. get some pics up bro
Old Mar 3, 2007 | 02:32 PM
Mxrider52's Avatar
I support for what?
I will get some tonight as it is still daylight.
Old Mar 3, 2007 | 06:29 PM
maximaman10's Avatar
Yes, you need to cut the wire!!!
Old Mar 3, 2007 | 06:36 PM
maximus_pr's Avatar
sorry to ask but this work the same on the I30??
Old Mar 4, 2007 | 02:06 AM
TurTLe*'s Avatar
if you dont cut the wire, you can possible get a brighter light source and burn up your wires since your putting more then 12v's into them at a higher amp rated or it can backfeed into the relay's ground.
Old Mar 4, 2007 | 01:45 PM
Cdg2125's Avatar
It might. you just need to find the correct wire in the highbeam relay. Once that is cut you just bring the power wire to a seperate source. Not too hard. Mine:
Old Mar 4, 2007 | 04:04 PM
jltibbs's Avatar
looks good bro. you have the blinkers modded to stay on at all times?
Old Mar 4, 2007 | 05:33 PM
Cdg2125's Avatar
yeah they're on all the time and blink
Old Dec 2, 2008 | 03:31 PM
kikoeltravieso's Avatar
this is great i'm going to try this on my maxima. thanks
Old Dec 2, 2008 | 03:41 PM
TLMNICK's Avatar
you HAVE to cut the wire....and this will work on an I30 too.
Old Dec 2, 2008 | 03:53 PM
4DRSpeed's Avatar
Project Ruby......
welcome to a year ago.
Old Dec 2, 2008 | 04:33 PM
nissanmax97's Avatar
anyone in the houston area know how to do this?
Sport
Jul 3, 2017 05:40 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
