Heater blows lukewarm and temp gauge shows "C"
Old Mar 4, 2007 | 05:59 PM
cditto's Avatar
If I run the A/C the temp gauge shows normal, but it was a cold morning today and I cranked on the heater and it only blew lukewarm air and the gauge never went above C.
Any ideas?
Old Mar 4, 2007 | 07:42 PM
KRRZ350's Avatar
replace your thermostat and flush your coolant, I also highly recommend spending the extra money and getting the t-stat from Nissan
Old Mar 5, 2007 | 01:38 AM
Trajiksmax's Avatar
Proud Maxima Owner
Could be air in the system. When was your cooling system last flushed & filled? If not recently, I would also suggest doing what KRRZ350 stated above ^^^.
Old Mar 5, 2007 | 04:31 AM
aaron-san's Avatar
Your thermostats probably stuck open.
Old Mar 5, 2007 | 12:58 PM
96max_manSE's Avatar
driving so slow aint easy
change your thermostat and fluids and dont expect to get hot air when you first start the car in the morning or after its been sitting for a while
Old Mar 7, 2007 | 06:17 PM
cam_honestiam's Avatar
Why has nobody mentioned your heater core???
Old Mar 7, 2007 | 06:21 PM
2da mizzax's Avatar
because the engine temp was low as well as the heat blowing out.
Old Mar 7, 2007 | 06:38 PM
I have been in a Chevy Cobalt that blew hot air long before the TEMP registered much above C. I missed, however, your statement that the needle did not rise above C. I agree with other: thermostat.
Old Mar 7, 2007 | 07:04 PM
MadMaxSE-L's Avatar
Doggah Bite...
Any ideas?
when I had my 95 Max it did the same exat thing- I replaced the t-stat and cooland and it was good to go
-Matt
Old Mar 7, 2007 | 07:59 PM
zexaccord's Avatar
rember also...your car does not run properly at anything below operating temperature. Although damage probably won't occur, running rich(what the car does when below normal) can foul plugs and sensors long term...not to mention decreased fuel mileage.
Old Mar 7, 2007 | 08:06 PM
MadMaxSE-L's Avatar
Doggah Bite...
running it colder than optimal can also lead to increased engine wear...
-Matt
Old Mar 7, 2007 | 08:12 PM
zexaccord's Avatar
^^^Correct. During intitial startup temps, most vehicle run 40% +/- rich. Can eat some SERIOUS fuel..and prob cause some decent dmg. FIX IT!
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
