Brakes brake fluid
Brakes brake fluid
Changing FRONT brakes. pads.rotors. Should I change brake fluid.? 1999 maxima never been changed. (fluid). 44,000 miles. If so is it difficult and can you do it by yourself or do you need someone to help. thanks.....IF you can suggest best fluid to use....
EDIT-Yes, change the fluid. Should be flushed everycouple of years from moisure absorbsion and the corrosive properties of the fluid.
Dot 3 fluid is the typical most fluids, if not exceeding that. If anything, I would say to only bleed the system and top it off when needed after you do the brakes. Unless you drive very aggressive, a fluid change is unnecessary at your mileage. As for doing it yourself, Brakes-yes, bleeding it yourself is possible through certain setups, but it is just easier to ask someone to help you. There is a technique, as for which wheel 1st ,2nd and so on. Search the stickies, the procedure is in there somewhere.
Originally Posted by 99BlackMaxMS
How do you flush the brake fluid?
Do dealerships/garages usually flush/top off the brake fluid when doing a brake job? I am just wondering because I assume that the previous owner did not do the brakes themselves, so in general do shops usually do it?
In general for pads and rotors, then no. But for calipers or other brake work where the system is open, then they should.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
