just bought a y-pipe, a few questions
Old Mar 8, 2007 | 06:18 PM
Dark99GLE's Avatar
I read the tutorial on how to install the y-pipe, it seems simple enough, but I had a question, it says to reset the ECU, how do I do this, just press a button or what?
Old Mar 8, 2007 | 06:22 PM
4x4Max's Avatar
Forget about resetting the ECU, it'll adjust by itself.
Old Mar 8, 2007 | 06:29 PM
Dark99GLE's Avatar
awesome, how long should it take? anything I need to be careful of during that time, or can I go flog it?
you're in cincy too? I'm over at UC, we should get a cincy maxima meet going sometime
Old Mar 8, 2007 | 06:33 PM
1996blackmax's Avatar
I believe it's something like 200 miles or so.....
Old Mar 8, 2007 | 06:44 PM
OnEBadAsSi30's Avatar
Just spray some PB blaster on the bolts make sure to take off the O2 sensor and install then ENJOY! Don't worry about the ECU they're shouldnt be anything to affect the ECU in anyway unless it recognizes HP
Old Mar 8, 2007 | 06:57 PM
Dark99GLE's Avatar
thanks everyone!
Old Mar 8, 2007 | 07:33 PM
Kta920's Avatar
just dont break the bolts! that is a bad thing.if its rusted it'll suck but take your time.
Old Mar 8, 2007 | 09:09 PM
96blackmaxSE's Avatar
boost me.....
Yeah...that happened to me, I broke off one of the studs because they were rusted...I could have avoided it if I used some lube like Bolt Loosener or WD-40 (Most Likely your bolts and studs are rusted)
Old Mar 8, 2007 | 09:13 PM
ImmaSquashYou's Avatar
good luck getting the bolts to the cat off..i had to get mine welded off......just be careful like other orgers said.....
Old Mar 9, 2007 | 10:01 AM
WD-40 is a light lubricant like for door hinges and what not. Put that PB Blaster on they're like its your job and let it soak for like 4 or 5 minutes they should come right off.
Old Mar 10, 2007 | 12:33 AM
Kta920's Avatar
hahaha oh yeah that sucked too,the cats never come off easy. i've learned to buy everything at once (y-pipe,cat,catback) and throw it all on at the same time....much easier.
Old Mar 10, 2007 | 10:41 AM
jmeister's Avatar
Congrats. When you coming to town next? Dyno day?
JRod28
Dec 29, 2023 09:56 PM
flu2000
22
Sep 2, 2015 07:29 AM
doobadoo
Aug 15, 2015 06:43 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
