Trying to make my car safer
Old Mar 12, 2007 | 11:34 PM
i30krab's Avatar
As you know I previosly mentioned that the 1995 &1996 4th gen max and i30performed poorly in the govt crash tests.
I am still upgrading my car to be safer since I will be driving it for a long time to come.
I pulled the front seats and found the slider is attached in the front of the seat with cheap rivets. We welded the slider to the seat bracket to fix this problem. Then we found the floor brackets on the outer door sides tack welded to the floor sheet metal so we welded this and fixed this problem. Finally I used 10-9 bolts to scew seats to floor.
Next , to protect my driver side door in case someone t-bones me I had a bar welded from the halo bar between the door and front seat and run forward in a lower position where a car or truck bumper would most likely hit the door. The roll bar builder said to keep it lower so it wouldn't crush the side of my chest.
The bar continues forward to the base of the kick panel where it is welded to a top plate and bolted to a lower plate under the car. Now I have this lower bar and the main halo to help stop a car from intruding into the drivers compartment.
Another thing they told me was if you're driving alone slide the passenger seat far forward because after reinforcing the seat this will act as a buffer if hit on the passenger side.
Old Mar 13, 2007 | 12:13 AM
SpeedCrazie's Avatar
I would be interested in seeing pictures.
Old Mar 13, 2007 | 02:35 AM
2da mizzax's Avatar
Don't forget your bicycle helmet and elbow/knee pads.
Old Mar 13, 2007 | 02:59 AM
dgeesaman's Avatar
Maintenance Monster
Man, to go thru all that effort and die because you got speared thru the window by a 4x4 on 12" boost.
Dave
Old Mar 13, 2007 | 04:56 AM
blimblam's Avatar
good idea. but stop jynxing him =]
Old Mar 13, 2007 | 08:20 AM
speed racer's Avatar
I think what you doing is great. If you get a chance take some pictures.
Old Mar 13, 2007 | 03:05 PM
i30krab's Avatar
I definitely will. Thanks
Old Mar 13, 2007 | 04:55 PM
Kind of OT but did you put in a fuel cell when you had that incident a couple of weeks ago? And if so which one? Lastly did you cut out the wheel well in the trunk? And if so what sheet metal did you use?
Old Mar 13, 2007 | 07:28 PM
i30krab's Avatar
I did have to install a new fuel pump because I let my fuel level fall to empty all the time and that shortens the pump life. I stayed with the walbro 255 hi-flo.
I didn't cut out my wheel well, I just whacked it in where it got in my way.
Old Mar 14, 2007 | 07:00 AM
Whoadie's Avatar
Mehn,
Not 2 Jinx u and all but I think All you 4gettin now is to pray to all the Gods 4 safety. Good job on the car.. You ought to imagine the stress for folks on motor cycles..
Later
Whoadie
Old Mar 14, 2007 | 09:01 AM
Fr33way™'s Avatar
Wild for Width
Originally Posted by Whoadie
Mehn,
Later
Whoadie
Can you please not type like this? Welcome to the .org by the way.
Old Mar 14, 2007 | 06:20 PM
Sounbwoy's Avatar
Yeah would love to see pics. Going forward the kick panel is a good idea and is done in pretty much any decent road race car with a full cage.
Old Mar 14, 2007 | 09:21 PM
96nismomaxi's Avatar
.org window licker
get a car seat it helps at least when the cops pull u over :Þ
Old Mar 14, 2007 | 09:36 PM
aznprid972's Avatar
I want to see pics if you do a full roll cage in there!!
Old Mar 14, 2007 | 11:00 PM
i30krab's Avatar
Not quite sure what you mean. Please elaborate!
Old Mar 14, 2007 | 11:05 PM
i30krab's Avatar
I'm definitely not going with a full cage. No room and I don't want any steel bars in front of my head. The halo bar behind the front seat is covered with
8 " of foam to protect the back of my head.
Old Mar 15, 2007 | 07:40 AM
Whoadie's Avatar
Hi,
Part of the Car and Driver theory is having fun while operating these awesome vicious machines. Respect the vehicle and its capabilities..
What are you really trying to accomplish? Sorry for the typo's on previous post.
Old Mar 15, 2007 | 12:07 PM
i30krab's Avatar
Hi,
Read the # 1 post in this thread. This is my everyday ride and the drivers in vegas are notorious for ignoring stop signs and red lights.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
