Downshift Error
Old Mar 14, 2007 | 07:01 PM
GStrength's Avatar
Downshift Error
My boy's 5spd has the ECU and the MEVI combo. He made a mistake and downshifted into 2nd from 3rd. RPMs went up to around 7,500. His engine is fine turns on and runs normal. When his car is off the gears in the tranny can shift into every gear, however once the car is on the gears are locked, i can press the clutch down but cant shift into any gear, and if i pull it to revearse it sounds like its grinding. There's a slight vibration in the clutch, can this be due to a bad slave cylinder or a bad throw out baring.
He was able to make it home in 5th gear but now cant shift into no gear when the car is on
Old Mar 14, 2007 | 07:38 PM
Torgus's Avatar
weird.
you can look and see if the slave cylinder is moving fyi...
leave it in gear and start the car...what happens?
i bet somehting is out of align in his gearbox.
if it were my car i'd either open her up and look around or call up a place that does trannies and ask him.
good luck
Old Mar 14, 2007 | 07:52 PM
GStrength's Avatar
If he puts it in gear and cranks the engine it turns on and begins to role when releasing the clutch but once he realease it completely to shift into second it becomes a ***** agian and doesnt want
mvm062
Nov 30, 2020 09:00 AM
junito1
Sep 23, 2015 12:14 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
Kalrakam
Sep 16, 2015 12:30 PM
