Fog light questions
Fog light questions
So I've been buying fog light bulbs, and have been duped several times. I've emailed the stores and ask them but whenever I installed the lights it all turns out to be yellow lighted... so I'm just wondering where can I get fog light bulbs that will end up being blueish/white instead of yellow? what website and what whattage should I get?
p.s. we need a lighting section
If you're just dealing with regular H3 bulbs, make sure the bulb has a light blue tint and it will produce white light. luminics, silverstars, piaa, etc.
ps. get stock wattage bulbs unless you plan on upgrading the wiring as well.
well I've bought H3 bulbs that were tinted blue but still came out to be yellow, but when I bought the car the color of light was white, but when those burned out I tried to find a replacement, but it all came out to be yellow, so thats whats frustrating me now. I can't seem to find a site that sells higher wattage H3s
I don't believe my fogs are HIDs, but the light still turns yellow even if it has a blue tint, so maybe its jus because 4000k H3s aren't strong enough, so I'm trying to find higher wattage H3s, but can't find any
I noticed my passenger side fog light was out the other day and just bought an H3 bulb from Checkers for $10, 55w should be the stock wattage, they also sell a 100w for the same price though, I havent installed it yet, probably do that later today, but I'll let you know what color it turns out to be.
No I think he meant are your headlights HID's.. as they'd make you fogs look yellower or greener than normal.
If you just have halogen headlight bulbs get the same brand for fogs, i think that'll be the only way to satisfy you
well I currently have the cheap ebay HIDs (just the bulbs not the ballasts) but I"ll be installing HIDs soon, thats why I'm trying to make my Fogs look more blue or white than yellow, but can't find any good bulbs
What's wrong with yellow?
Anyway, it sounds like the look you want is the blueish "hyperwhite" color, as opposed to "regular" white light. Any of those halogen blue tinted bulbs will do the trick.
Originally Posted by phenryiv1
So do you have a bunch of H3 bulbs that you are not using? Are they YELLOW light output, or do they just have a slight yellowish-tint, as conpared to a "white" bulb?
If your going HID's with your headlights then it is best to go HID's with fogs or else anything blue tinted halogen will still look very yellowish or worse greenish depending on what K you go with. The only halogen with hidish white are those crazy 100/110 watt nokya bulbs and I'm sure you don't want to go that route.
[IMG]http://img409.imageshack.us/img409/5527/img0192dq7.jpg[IMG]
Originally Posted by JasonR107
good deal, so had you not put any of the ones you ordered in before? or were you just guessing what color it would appear based on the bulbs look?
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
98nismomax
08-13-2015 12:44 PM
