o/d on dash cluster flashing???
Old Mar 17, 2007 | 08:48 PM
max ride 41's Avatar
ok, started the car up last night to go grab a bite and did'nt notice whether or not it flashing that time. but leaving wawa it flashed several times and then stopped. got home, turned the car off, and re-started twice, did'nt do it. i had to gun it back and fourth to get unstuck from the snow, would that trigger anything??? car sems to be running fine, any idea's??? thanks in advance.
Old Mar 17, 2007 | 11:28 PM
hollaatchaboi's Avatar
Mine actually did th same tonight. I was told that it may be something wrong with the transmission.
Old Mar 17, 2007 | 11:31 PM
from the stickies:
My OD light is blinking, what does that mean?
The credit goes to ripper7 for this information.
AT diagnostic
__________________________________________________ ________________
95-97
1. Start engine and warm to normal operating temp with O/D off.
2. Turn ignition swith to off postiton wait 5 sec.
3. Turn ignition switch to the ACC position.
4. Put O/D to ON.
5. Move shifter to P, turn ignition on but don't start engine.
6. The OD light should come on for about 2 secs.
a. if light does not come on somthing is wrong with the trans. computer.
b. if light comes on proceed to no 7.
7. Turn ignigton key to off.
8. Turn ignition key to on, don't start engnie.
9. Move shift lever to D, trun ignition to off.
10. Put O/D switch to off position.
11. Turn ignition off.
12. Put O/D to off, turn ignition ON wait 2sec and move shifter to the 2 position.
13. Put O/D to on, move shifter to 1 position.
14. Put O/D to off, depress accelerator all the way to floor and release.
15. The computer is now in output mode and will start displaying the codes.
There’s one long flash that signifies the start of the sequence. Following
should be 10 short flashes. Then it
repeats.
Remember the first long flash indcates the start of the sequence followed by
10.
All 10 flashes the same = No error codes read at this time
1st flash longer than others = Revolution sensor is shorted or disconnected.
2nd flash longer than others = Speed sensor circuit is shorted or disconnected.
3rd flash longer than others = Throttle sensor circuit is shorted or
disconnected.
4th flash longer than others = Shift solenoid “A” circuit is shorted or
disconnected
5th flash longer than others = Shift solenoid “B” circuit is shorted or
disconnected
6th flash longer than others = Overrun clutch solenoid circuit is shorted or
disconnected
7th flash longer than others = Lock-up solenoid circuit is shorted or
disconnected
8th flash longer than others = Fluid temperature sensor is disconnected or A/T
control unit power source
circuit is damaged.
9th flash longer than others = Engine revolution signal circuit is shorted or
disconnected
10th flash longer than others = Line pressure solenoid circuit is shorted or
disconnected
All the same with no long start flash = Battery low, been disconnected, or
control unit has just been
reconnected.
Old Mar 18, 2007 | 01:02 AM
thanks man, i'm gonna check later on this morning. if it is the same flashing as stated at the bottom of the post, could that be from sitting all day in the ccold weather?? like i said, runs fine ( ******* computer....)
Old Mar 18, 2007 | 09:18 PM
ok, musta been a fluke, but no more flashing. drove it today and no flashes at all, friggin car is constant worry, jeeez.......
Old Mar 18, 2007 | 09:23 PM
MaximaSpd85's Avatar
disconnect your drop resistor lately?
Old Mar 18, 2007 | 09:31 PM
Cdg2125's Avatar
Yes depending on the flashes it will tell you what is wrong. Usually it means that there is a problem with a solenoid.
Old Mar 19, 2007 | 07:54 PM
had a 02 sensor put in 2 weeks ago, and it did'nt flash at all today either. i read in a stickie that 10 flashes indicates no codes and or problems at the time it happens. car ran perfect today too.
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
dshinn
Sep 26, 2015 08:07 PM
