UDP installed......now problems!
#41
If things are normal with the stock puller something has to be off with the UDP. I wish someone that had one would jump in here. But I still guess that its the UDP. Have you thought about having a shop install it for you and see if they get a better result?
#42
#47
Well from what i can gather it must be the pulley. If you took off the UDP and put on your stock pulley and the car ran good again, then it must be the pulley. Hopefully the previous owner has the reciepts and unorthadox will return it. Other then that, it is very possible that this one was defective from the factory, it does happen, you just turn out to be the unlucky one. Hopefully everything gets straigtened out.
Good luck!
Good luck!
#48
I forgot to ask. What size and brand belts are used with the UDP? Do they come with the pulley?
Hope that helps!!
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
HerpDerp1919
09-29-2015 02:02 PM
