Header Question...
Old Mar 23, 2007 | 05:33 PM
99BlackMaxMS's Avatar
Header Question...
How easy is it to remove the stock headers? I just bought a 99 cali spec with the precat built into the header and I was thinking about replacing it with a fed spec header when I get a new y-pipe. Just wondering what the process is and how difficult it is.
Old Mar 23, 2007 | 05:46 PM
MadMaxSE-L's Avatar
Doggah Bite...
From looking underneath my car when I put on my Y-pipe, the front header is probably not a problem, but the back one looks like a major PITA...
My car is fed-spec also, so I have more room to work with than you will.
Old Mar 23, 2007 | 06:21 PM
Just want to make sure tho...the header with the precat is the front header. The back header is the same on all 4th gens. Correct?
Old Mar 23, 2007 | 06:36 PM
jltibbs's Avatar
once you remove the front header you can brace the engine to the front to have easier access to rear header. hope you have a lift bro!
Old Mar 23, 2007 | 07:42 PM
NYC32798's Avatar
I'm actually in the middle of the install. I started a few hours ago and decided to finish it up tomorrow. It wasn't as bad removing everything like I thought it would be. The front headers I was able to get out without removing the radiator or fans. The rear I didn't have much trouble with either once the y-pipe and crossmember off. One thing that bothered me a bit was getting the egr tube back on. It was a pain to line the nut up. At this point, I got the front headers bolted on as well as the y-pipe. I have 3 more nuts/studs to go in the back that are giving me a hard time but other than that, it's not that bad. Just be patient and take your time.
Old Mar 23, 2007 | 08:07 PM
Cdg2125's Avatar
is it even a smart thing to do to switch cali spec headers to fed spec?
Old Mar 23, 2007 | 08:38 PM
supazn
i'm pretty sure all you need to change is the front header
Old Mar 23, 2007 | 08:48 PM
Cdg2125's Avatar
gotcha. Good to know install isn't that bad. If anyone is ever selling cattman headers for cheaper I might jump on them.
Old Mar 24, 2007 | 12:19 PM
Ok, I can get a Warpspeed Alum. Y-pipe for $125+shipping and I assume I can get a front header from a 95-99 fed spec for $50ish...How hard is this to do...as i could see about a 20 hp increase for about $200 in parts?
Old Mar 24, 2007 | 01:23 PM
Cdg2125's Avatar
You'll see about 20hp yeah. The y-pipe will give 95% percent of it but getting rid of the cali spec header will give a little extra too.
Old Mar 24, 2007 | 01:24 PM
supazn
just get a cali spec y and be done with it, it isn't worth it to get extra 02 bungs drilled.
Old Mar 24, 2007 | 01:27 PM
nismology's Avatar
A cali-spec y-pipe doesn't eliminate the front precat. You'll leave some power on the table unless a fed spec front manifold is installed.
Old Mar 24, 2007 | 01:30 PM
I just figured that while I had the exhaust apart...I may as well get a fed spec header. I don't plan on getting both new headers but a used fed spec front would eliminate the precat and get that extra hp.
However it sounds like its a PITA and I can just put on the y-pipe and get a new cat and call it done. (the b-pipe and muffler are relatively new)
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
ac max 92
Sep 17, 2015 07:35 AM
Maxboy23
Sep 4, 2015 06:04 PM
