Help - Squeaking Noise Driver's Side
Old Mar 30, 2007 | 06:47 AM
smackdownGTR's Avatar
Hey fellow .orgers
For the past few months everytime when I close the driver side door or when I go over bumps I hear a squeak by the front driver side panel. It sounds like something is loose. It can't be the struts because when I push down on it it does not squeak. It only happens when I slam the door or over bumps. Anyone had this issue and how was it fixed?
thanks!
Old Mar 30, 2007 | 07:01 AM
Fork's Avatar
Maximaler Experte
Wow, I have EXACTLY the same issue smackdown. I think it's coming from inside the drivers door or just underneath. It's a little disconcerting isn't it?
Old Mar 30, 2007 | 07:16 AM
2da mizzax's Avatar
Its the foam on the backside of your door panel.
Old Mar 30, 2007 | 07:37 AM
Fork's Avatar
Maximaler Experte
Bingo! I knew it was something simple... Now that I know where, it's NBD.
Thanks mizzax - it's appreciated.
Old Mar 30, 2007 | 08:19 AM
Totally makes sense! I had to open up the door panel to replace the driver side mirror. Perhpas I shifted the foam. I will check it this weekend!
Thanks guys!
Old Mar 31, 2007 | 08:14 AM
MaximA VlaD's Avatar
i have a squeaky noise in the back of the car when going over speed bumps... or even making turns with even a little body roll. might be suspension or bushings on the 'beam.'
anyone have a similar noise from the back?
Old Apr 3, 2007 | 11:02 AM
Hmmm.. I checked this weekend and it's definitely not the foam inside the door panels. It's definitely under the front of the car. Could it be a loose sway bar or struts?
Old Apr 3, 2007 | 12:59 PM
2da mizzax's Avatar
could be strut bearings or a bunch of other things. intial post made me think it was coming from inside of the car.
Old Apr 4, 2007 | 06:18 AM
heynow's Avatar
check your swaybar endlinks. Mine we're pretty messed up and made a squeak on even the smallest bumps or getting in/out of the car(driver's side too)
Old Apr 4, 2007 | 06:52 AM
zoman85's Avatar
i got a lot of squeaky noises from the front end. just driving on the highway or going over small bumps makes it squeak like a mother. i've greased stuff up, checked and re-checked the front end and everythings nice and tight. any help?? its gotten worse over the past couple of months. i also get this squeaky noise from the right strut, and ive changed the strut mount but still having the same problems, could it be a bad strut or both front struts making that noise?
Old Apr 4, 2007 | 06:53 AM
Keatz's Avatar
I had a squeak noise like that a long time ago, it turned out my exhaust hangers were loose and rusted, you might also want to give that a quick check. When i was checking, i just hit the mid section of the exhaust and presto, that was the noise.
Old Apr 4, 2007 | 10:08 AM
sheeple's Avatar
I have this same problem except it's gotten noticeably worse, but I think it might be my front end suspension
Old Apr 4, 2007 | 10:19 AM
sheeple's Avatar
sorry for the quick thread jack but it won't let put up a new thread... dunno why but I saw this post http://forums.maxima.org/showthread.php?t=516458 and was wondering if these have that problem cuz I was thinking of just upgrading to these
http://www.tanabe-usa.com/springs/sp...tions.asp?id=1
boomerbrian
Oct 31, 2018 10:25 AM
AcuraLegend
Oct 17, 2016 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
