in/out size for catalytic converter
Old Mar 30, 2007 | 12:07 PM
MaxiiMa's Avatar
what is the in/out size for the stock exhaust pipe 95 maxima... i found a cheap catalytic converter... all i need to know is what size... 2.25" in/out... 2.5" in/out... i'm thinking 2.5", my setup is stock... this will be the first time i'll take out the stock converter and weld in the universal since a direct oem fit was too expensive...
Old Mar 30, 2007 | 12:20 PM
MaxiiMa's Avatar
hope i'll get some quick response i need to place this order right away... so it'll be delivered asap... thnx
Old Mar 30, 2007 | 01:02 PM
pmohr's Avatar
No more Maximas...
Stock exhaust is 2.25in, i would imagine cat is the same.
Old Mar 30, 2007 | 01:13 PM
MaxiiMa's Avatar
if i get a 2.5"... would it be easier to weld... 2.25" would go inside the 2.5" and weld without having to worry much about leaks.... or is it recommended to weld a 2.25" to a 2.25"...
is there a way to measure it...
Old Mar 30, 2007 | 01:16 PM
MaxiiMa's Avatar
2.50" Inlet Pipe, 2.25" Outlet Pipe
i found this after searching google.... can anyone verify
Old Mar 30, 2007 | 01:18 PM
95bluse's Avatar
should weld no probs..that's what I have with my stock b-pipe. My Budget y-pipe bolts directly to my magnaflw hi-flow cat (which are both 2.5")
Old Mar 30, 2007 | 02:15 PM
bigpulve+'s Avatar
IIRC Its 2.5in in and out.
Old Mar 31, 2007 | 01:20 PM
RA030726's Avatar
I'm nutty for Nissans
Stock is 2.5" in and 2.75" out.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
