I did something pretty stupid today... need help!!
Old Mar 31, 2007 | 08:45 PM
VQmaxi17's Avatar
Today i was working on changing the valve cover gaskets on my 95 maxima, and I accidentally dropped one of the ignition coil screws down the dipstick hole. I just can't believe that of all places for it to drop, it ended up there. I tried looking down the hole to see if it was stuck, but didnt see it. I also tried sticking a small telescoping magnet down to see if i could fish it out, but the magnet wouldnt fit far enough down. does this hole just go to the oil pan? If so, could i just try to drain the oil and hope the screw comes out with the oil? If not, where could it have ended up? Any help at all is GREATLY appreciated!!
thanks guys...
Old Mar 31, 2007 | 08:56 PM
DcMaN's Avatar
your best bet would to drain the oil, and drop the pan and pray it made it down there other wise i would assume your pretty SCREWED no pun intended lol.
Old Mar 31, 2007 | 11:16 PM
MadMaxSE-L's Avatar
Doggah Bite...
You could try draining the oil pan and seeing if there is any chance in hell that it will come out with the oil. If it doesn't, then after you have drained the oil and with the drainplug still out, take a large/strong magnet and swipe all over the bottom side of the oil pan on the outside- maybe you can drag it out through the drain hole.
Just a thought...
Old Apr 1, 2007 | 12:44 AM
andrei3333's Avatar
try a large subwoofer , bring its magnet to the bottom of the pan, maybe ?
Old Apr 1, 2007 | 01:05 AM
MadMaxSE-L's Avatar
Doggah Bite...
Something to that effect, yes.
Old Apr 1, 2007 | 03:42 AM
90stanza's Avatar
drain the oil and pull the pan if that doesnt work try a big magnet. whatever you do dont start the car untill you get it out.
Old Apr 1, 2007 | 05:52 AM
ALSOUSA99MAXIMA's Avatar
didnt madmax already say a magnet?!?!?!
Old Apr 1, 2007 | 06:01 AM
MDeezy's Avatar
Damn, down the dip stick hole... what are the chances of that.
Old Apr 1, 2007 | 07:57 AM
VQmaxi17's Avatar
dang... and i just changed the oil last week
thanks for all the suggestions... i guess ill take out my sub and try to pull it out with the magnet first, and if that doesnt work ill just take the pan out and pray its there...
Old Apr 1, 2007 | 08:40 AM
MDeezy's Avatar
Just to restate it again.
Its in the lower oil pan, the dip stick is a straight tube to the lower oil pan, so if you havent started the car since it fell, it is in the lower oil pan, drain the oil, and use a magnet, worse come to worse, pull the lower oil pan and you should see the bolt clear as day. Clean the pan, remove old rtv, apply new and seat and tighten
Old Apr 1, 2007 | 11:42 AM
UkiSash's Avatar
yep
its not that bad the worse part about this is you have to drain the oil....
Old Apr 1, 2007 | 08:48 PM
VQmaxi17's Avatar
now that is something that I lOVE to hear...
again, thanks for all the help!
...what would we do without the org??
Old Apr 1, 2007 | 10:26 PM
HondaKiller718's Avatar
Start the car! Start the car!! Do it, Do it!
What ever happened to the power of peer pressure??
Old Apr 2, 2007 | 08:45 AM
90stanza's Avatar
Just restating like MDeezy did.
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
Sep 27, 2015 08:37 AM
