NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Jul 22, 2009 | 10:10 PM
  #4281
Jaeinda97's Avatar
Originally Posted by pmohr
Then it's some other intermittent issue, and we'll go from there.
Short of the clutch switch, I'm leaning towards a loose connection or worn out ignition switch.
LOL alright no problem with that at all I will definitely check it out 2morrow fill you in on my results i came up with, so this problem has nuffin to do with the slave or master clutch cylinders at all right
Old Jul 22, 2009 | 10:13 PM
  #4282
pmohr's Avatar
No more Maximas...
No, again the clutch and it's operating components are irrelevant to whether or not the starter will work, short of the clutch switch.
Old Jul 22, 2009 | 10:19 PM
  #4283
Jaeinda97's Avatar
Alright just making sure that those were out of the picture.. Thanks in advance and hopefully ur right about this 1.. Laughing but 2morrow i will fill you in on the results to the paperclip..
Old Jul 23, 2009 | 12:23 AM
  #4284
PersianCzar's Avatar
Originally Posted by Blackwind
its fine just widen the bracket some.
Well its not about widening it, because its not like the fuel filter case has got bigger. Since elbow is missing, I need a slightly longer tube now (~2 inches). Because filter doesn't even reach the firewall to attach to bracket. With 2 extra inches of tubing, it will get me to the bracket. But even without the filter being in bracket, is it worth all the trouble to correct this or is it ok without??
Old Jul 23, 2009 | 12:31 AM
  #4285
Blackwind's Avatar
oh i got ya now, you can let the filter hang or you can make this a weekend project and modify a setup that works for you.
Old Jul 23, 2009 | 12:36 AM
  #4286
Are you sure the filter you replaced was OEM? Are you the original owner of the car?
I've never seen an OEM Nissan filter (for the A32, anyway) with an elbow for the upper hose.
No, im not 100% sure the filter that was replaced was OEM. I am the original owner tho, however 2 other family members also drive this car so there could be a possibility that since 1996, someone might have changed it without letting me know. Benefit of the doubt, what more can I say?! Filter says "Made in Japan" and "Outlet" on the top and no other markings, in case you wanna know.
Just not sure if I let it lean on the bracket as oppose to IN the bracket is okay or not. What u think?
Car is at 191K and this tune-up greatly changed the performance. I can actually feel the difference with every step on the gas pedal.
Old Jul 23, 2009 | 12:49 AM
  #4287
It would be ideal to correct this. However, I went to courtesy parts to buy this part and it says "This part is no longer made by nissan north america....". This was for the top hose.
So now I gotta take the old fuel filter and get a compatible diameter fuel-grade hose. Where should I check, u think napa or autozone would have ones for other cars that I can take and just modify?
Old Jul 23, 2009 | 12:52 AM
  #4288
pmohr's Avatar
No more Maximas...
It's 5/16" or 8mm hose. You can get it in lengths from most parts stores, either off of a spool, or in one of the aisles. Absolutely no need to get it from Nissan, when a 2 foot roll usually goes for ~$8.
Get some new clamps as well.
Old Jul 23, 2009 | 06:42 AM
  #4289
hoodibaba's Avatar
pmohr,
Hey guys. I recently noticed that my steering wheel seems to stiffen up at variable speeds..PS fluid was drained and refilled recently using the turkey baster method..it also makes some moaning sounds when I turn but its inconsistent..any ideas..thanks
Old Jul 23, 2009 | 10:15 AM
  #4290
Jaeinda97's Avatar
Hey Pmohr I tried your paperclip to see if it works and it still didnt start im not sure if i even did it right but i did unplugged the clutch switch and stick the paperclip into 1 end and to the other is that the correct way in doing it??.. But regardless the car still didnt start right up
Old Jul 23, 2009 | 04:21 PM
  #4291
That's good to know, thanks for the spec on that.
And upon further investigation, the filter was not the OEM since it was last replaced at a GoodYear in 2003. My bro actually saved the invoice, something useful he did, haha. ****** looked like they cut the tube so it can fit this Fuel Filter with the elbow, because the upper hose on one side is slightly jagged and not perfectly cut. Bas-TERDS!!!!
Old Jul 23, 2009 | 05:07 PM
  #4292
eFLO's Avatar
Misfiring SES codes
i have a 99 maxima, throwing 0603, and 0201. i just got a coil and will replace it. but today i took the car in for an oil change, and noticed the exhaust gas was smelling like sulfur. could the misfire in the engine somehow cause the cat to go bad as well?
Old Jul 23, 2009 | 05:10 PM
  #4293
pmohr's Avatar
No more Maximas...
Yes, this is why you should never drive a car when it's misfiring unless absolutely necessary.
Was the CEL flashing?
So you jumped the two pins on the harness with the paperclip, and it still wouldn't start?
I would still bet on the ignition switch, myself.
Old Jul 23, 2009 | 05:16 PM
  #4294
eFLO's Avatar
It was not flashing just solid. Damn, guess that's next on my to do list. could i have screwed anything else up by driving it?
btw thanks for that quick response!! lol
Old Jul 23, 2009 | 05:18 PM
  #4295
pmohr's Avatar
No more Maximas...
Unlikely. But if it's misfiring heavily, it's dumping raw fuel into the exhaust, which clogs up the cat.
Old Jul 23, 2009 | 05:32 PM
  #4296
eFLO's Avatar
alright gotcha, which brand cat should i go with? i searched quick and saw magnaflow seems like a good choice.
Old Jul 23, 2009 | 06:19 PM
  #4297
Jaeinda97's Avatar
Nope not a crank at all but alright i was watching this video on youtube on how to check an ignition switch soo i guess when i have time i will go and see if its that.. Do u think my clutch switch is just bad and thats why it wouldnt start just by depressing on the clutch
Old Jul 23, 2009 | 06:21 PM
  #4298
pmohr's Avatar
No more Maximas...
This one? http://www.youtube.com/watch?v=4ykT9...C2C64F&index=3
The entire point of jumping that harness was to completely bypass the clutch switch, to rule it out. You did get the correct one? You want the one at the bottom of the pedal, not the top.
Old Jul 23, 2009 | 06:31 PM
  #4299
Jaeinda97's Avatar
Yeap Thats the same exact video i seen.. Daamn u gd with this joint 4real but anyways i didnt do it that way at all soo i guess i retry it that way again 2morrow.. and again i will fill you in on my test.. soo do i put both points of the paperclips in the clutch botton??..
Old Jul 23, 2009 | 06:32 PM
  #4300
pmohr's Avatar
No more Maximas...
I made that video a little while ago, there are a whole bunch of others there too.
You disconnect the harness from the switch, then you stick the paperclip in the connector for the harness, not the switch itself.
Old Jul 23, 2009 | 06:43 PM
  #4301
J RO 9's Avatar
after an alignment on tuesday, i was told that my sway bar end links are shot.
i just wanted to make sure i was going to order the right ones,
are these it?
http://www.courtesyparts.com/54618-a...tml?cPath=1783&
part # 54618-A32B001
Old Jul 23, 2009 | 07:09 PM
  #4302
pmohr's Avatar
No more Maximas...
are these it?
If you are getting just the endlink itself, and none of the washers, bushings, etc. In that case yes, that's the correct item.
Otherwise, this is what you need per side:
54618-0E000, $23.41 each at Courtesy
2 56113-60U05, $1.97 each at Courtesy
2 56112-V0100, $3.55 each at Courtesy
01223-00291, $1.17 each at Courtesy
01225-00261, $1.09 each at Courtesy
Obviously this adds up, before tax/shipping you're looking at $36.71 per side.
No real reason to go OEM IMO, just grab a kit from an auto parts store. Looks like ~$27/side for Moog, ~$20/side for TRW, etc.
Old Jul 23, 2009 | 08:39 PM
  #4303
J RO 9's Avatar
i'm definitely down to save money and get something if it's comparable to OEM. are Moog and TRW brands you are referring to?
and if i went to my local auto parts store, what exactly do i ask for?.. do i ask for a 'sway bar end link kit'?
Old Jul 23, 2009 | 08:40 PM
  #4304
pmohr's Avatar
No more Maximas...
Yes, they should (hopefully) understand what that means.
Old Jul 24, 2009 | 12:32 AM
  #4305
jhonny's Avatar
hi,
so, i've a question for you how long would it take to install the strut mount bearing?
btw i've found some of the strut mount bearings and they are KYB. are they good?
Old Jul 24, 2009 | 04:49 AM
  #4306
J RO 9's Avatar
Originally Posted by jhonny
hi,
i have them. they are fine, although some people around here say that KYB has fitment issues on things other than shocks/struts.
shouldn't take more than 30 minutes IMO.
jack up the front wheels, remove wheels, remove the spring/strut assembly, swap the strut mounts, and put the assembly back in.
Old Jul 24, 2009 | 02:16 PM
  #4307
Jaeinda97's Avatar
I am happy in 1 way and confused in the other way i did the paperclip and still no start soo i got upset again and just rmr that i watched your post on youtube the other day and decided to just do it and as happy i was it started right up like the video but then i was confused like whats the problem and the cost of it.. Could u help me out again with this??..
Old Jul 24, 2009 | 02:29 PM
  #4308
pmohr's Avatar
No more Maximas...
So you turned the ignition switch with a screwdriver and it started up fine?
You could try to shim the opening a bit (see the link in the description of my video for DBear's post), or just replace the ignition switch.
48750-1E411, $30.86 each at Courtesy
Old Jul 24, 2009 | 06:23 PM
  #4309
jimr's Avatar
97 Max Auto trans wont go into any gear!
I bought a used 97 max about 3 months ago. The other day my wife was pulling into the driveway and hit a small pot hole. When she did it like popped out of gear and she coasted to a stop. When I looked at it, it just grinds when you try to put it into any gear. My guess it that the trans is ok but something else is wrong with it. She did say that the day before it was a little odd shifting into second gear but who knows.
I did check under it and nothing seems to be damaged. I am unemployed so I need to fix this myself.... or not! I have always done my own work including engine and trans swaps but that was on American cars for the most part.
Thanks for your help!
Old Jul 24, 2009 | 06:30 PM
  #4310
pmohr's Avatar
No more Maximas...
Well I would assume this is a 5MT, except you say 'auto' in the title (which by the way, never use the title for important information; 99% of the time it'll be overlooked).
What exactly is 'grinding'? The trans or something else?
So when it 'popped' out of gear, does this mean that the shift lever physically moved?
Have you checked trans fluid level and condition?
If you put it into gear, it immediately grinds, or does it only happen when giving it gas? Does this happen with your foot on the brake, or only off?
Have you observed the axles while putting into gear, and seeing if they all rotate as one piece? It's possible one of the axles broke. Don't assume it's fine with a quick visual, you must actually observe it turning; a CV joint could be broken yet leave the boot intact.
Basically, you'll find the problem by actually finding out exactly what is grinding; this requires you to actually get underneath the car.
Old Jul 24, 2009 | 09:08 PM
  #4311
Jaeinda97's Avatar
Honestly watching your video really solved my problem i cant lie at all but im thinking i am just gonna replace it and hope i can do it myself by putting the ignition switch
My reasons are because the switch turns an extra 3 clicks to start and thats why i couldnt be able to start it with just the key itself i guess all those times when i was depressing the clutch and starting it at the same time messed up the ignition switch even more..
But to experience something new doing on my Max i will definetly try to add a lil tape to it and see what i get but im still getting the switch since its soo cheap..
Are they gonna send it with a complete wire set or just the switch itself??.. cause if its just a plug and play thing i will do it myself no need to pay somebody to do so..
Buts Thanks alot Pmohr u saved me alot of time to bring it to the shop and make them not kno whats wrong.. and make me spend more money for parts i didnt need..
  #4312
jimr's Avatar
I am going to try to make this easy so I will reply to each question after the question!!!! I really do appreciate your help. I have been looking for help for 2 days and then I cam upon this site. TY so much for being here!
Well I would assume this is a 5MT, except you say 'auto' in the title (which by the way, never use the title for important information; 99% of the time it'll be overlooked). I posted on another forum - that wanted to be paid for the answer! and they wanted in the title. I guess some know about autos and some mans.
Its the trans gears - I feel iy in the shifter
I wasnt there so I am not certain but she said it sounded funny and "it didnt go" (lol) when she pressed the gas.
Yes, it was about half a pint low, smelled fine. I filled it and no help. Same condition.
It immediately grinds going from park to any gear and back. I did have my foot on the brake..... just in case!
No I havent. I just gave it a quick look. I was in the car and it never seemed to have power to the axles. It never engaged in any gear.
I am a big guy and I dont fit! lol I got my head under there and even in park as you rev it a bit there is noise from the trans area.
Hope this helps!
Old Jul 24, 2009 | 09:18 PM
  #4313
pmohr's Avatar
No more Maximas...
Yes, it's the switch itself plus the wiring harness.
Hope this helps!
Also, don't reply inside of a quote. It means that in order to find out what the hell you said versus what I said, I've got to go through line by line, and edit it manually. There is a quote feature for a reason, you can easily quote each question individually.
All gears in the auto trans are constantly engaged; they never disengage (shouldn't, anyway). Unless one or more broke (rather unlikely), you shouldn't feel any of them.
That could be pretty much anything.
How do you know that it didn't engage in a gear, versus being in gear and the axle making the noise? Even at idle is more than enough to spin a broken axle, and you won't really notice a decrease in RPM.
Have you tried to pinpoint exactly what is grinding, or where?
Can you take a video clip?
Old Jul 24, 2009 | 09:48 PM
  #4314
jimr's Avatar
I will see if I can video it but I dont have a video cam but may be able to borrow one.
Didnt know the gears were always engaged! So hearing grinding in all gears makes sense. Maybe it is an axle, never gave that any thought but what do I know! lol
I have not tried to pin point it, just took a quick look at it when iIdropped her my Pathfinder to use. (She is actually my ex wife and I sold her my 97 Pathfinder LE for what I paid for it! I am a sucker!!!! But she needs it - I am unemployed) But I will as soon as I get it to my place.
Old Jul 24, 2009 | 09:58 PM
  #4315
watson's Avatar
So I replaced my alternator and now I have a constant belt squeeling problem, I tried tightening the belt tensioner but it did not fix it. Even tried belt dressing and its still really bad. Its even squealing when im driving, now the belt is a pretty new belt. Should I try tightening it again to make it tighter? For when I tighten it I have to loosing the pulley and get someone to push down on it since I do not have a bolt to twist. Any help would be greatly appreciated asap since I am going on a road trip tomorrow morning.
Old Jul 24, 2009 | 10:21 PM
  #4316
pmohr's Avatar
No more Maximas...
You've got a tensioner missing parts, and you're wondering why the belt won't get tight enough?
Fix the tensioner, problem solved.
Old Jul 24, 2009 | 11:44 PM
  #4317
DBrames's Avatar
hey i tried the factory alarm beep mod tonight, http://www.vqpower.com/v2/articles.php?article_id=49
well i got it all hooked up and all and when i hit the lock button the buzzer sounds but then for some reason the blinkers stay on constant... front and backs. i double and tripled checked my wiring and did it exactly as it said and ive thought about it for a couple hours now and could not figure out what the issue was.
anyone had this problem? or think they know what the issue is?
thanks
Old Jul 25, 2009 | 02:09 AM
  #4318
watson's Avatar
Anyway that you could find the part number for me? I looked on courtesy but still couldn't find it, also is it safe to go on this road trip with the belt loose?
Old Jul 25, 2009 | 11:26 AM
  #4319
pmohr's Avatar
No more Maximas...
It's safe as long as it's tight enough to work the alternator, otherwise you'll just be running on battery power.
Exactly which part are you missing? Can you point out the part code here?
Old Jul 25, 2009 | 10:30 PM
  #4320
Jaeinda97's Avatar
[quote=pmohr;7129603]Yes, it's the switch itself plus the wiring harness.
Thanks a lot now that i already did the whole finding the ignition switch im just gonna do it right after i order it on courtesy.. as soon as its delivered to my house im putting it on and start driving Maxinea again.. Thanks Alot Pmohr for the tips and ur GREAT HELP.. I be back again for some more tips LOLZ
