NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
So i recently changed my camshaft P.S and its been starting fine..now my car shuts off randomly at a red light unless i throw it in neutral and rev lightly to keep the rpm up..now i do have an exhaust leak which i doubt would cause that cuz i always had that..and i hve an oil leak around one of my coils..take out the coil and its dranched but again i had that leak and it never shut off before..any suggestion?
When the car is at idle, air is bypassed around the TB and into the engine using the IACV. If the IACV is messed up, then no air will flow into the engine, and to keep the car running, you have to give it gas to crack open the TB plate.
Sometimes cleaning the MAF and TB is the fix. Sometimes the IACV is so far gone, u need to replace it.
Ive got a quick question about the bose system in a 97, when i have the cd or radio on it only plays through the door speakers/tweeters and when i play the tape it only plays on the driver side door. About 6 months ago i had accidently played the radio with the back pass. side speaker/amp unconected and when i plugged it in that speaker wouldnt work. i just drove around like that and about a month ago the other rear speaker stopped working. do you think its possible i messed up the pre amp in the radio if it even has one, and if it doesnt what could be making it do this??? thanks
Lose the BLOSE and get a new system
The oil light comes on after it stalls? That's normal. The car is "ON" but it not sensing any oil pressure...
European 4th gen
Hello, Im new to this forum. Im from Finland sorry for my bad english in this matter.
(Nissan maxima 1999)
I'm about to buy a maxima and would like to know the difference between european maxima and american. I know the fact that the front/back lights are different, but what about body? if Im to buy a bodykit from america, would it fit the EU maxima without problems etc. etc. I tryed to post pictures but i dont know how to
I get my information from looking at a parts list. The website is Nissan4u.com. I looked at a Northern European Maxima and a USA maxima parts list. Here are 2 links for the front fenders.
This is the Northern European Maxima:
http://nissan4u.com/parts/maxima/el_...r_and_fitting/
This is the USA Maxima:
http://nissan4u.com/parts/maxima/us_...r_and_fitting/
96 i30t Questions
Hey everybody! I'm planning on doing a few upgrades on my 96 i30t:
Wheels, Cefiro headlights, Cefiro Sport VIP grille and Polyurethane Headlight Eyelids
Now I've been searching around and couldn't really find a straight forward answer so I'm hoping someone can help me.. I'm trying to figure out first, whether or not these tsw zolder 5: 19x8.5" -235/35R19 will fit without rubbing or do I need to lowering springs/ bolt adapters?
Second question is does anyone know where I can acquire one of these grilles with the mesh?? Is it just a Sport VIP grill with custom work?
And finally I'm gonna buy the one piece Cefiro headlights and eyelids. Do these http://www.paradox-systems.com/produ...roducts_id=158 maxima eyelids fit on a 96 i30t?
Self-Unlocking Door and Cannot Program FOBS--Baffled!!!
The first thing I would do is disconnect the data line at the master switch (R/B, pin 1) and see if it still unlocks by itself. If not, the unlocking is being commanded by the BCM (possibly an internal problem, or receiving input from the MRCU), or if so, it's a problem with the master switch itself.
I would be suspect of the BCM being at fault, either internally or being requested by the MRCU, given the issue in programming in a new remote.
Having copies of the key doesn't matter for any Nissan earlier than '99, that's when NATS was first introduced.
Should I try replacing the BCM next, or is there another way to find out if the MRCU is causing the issue before buying/installing another part? I've already installed a master switch and door lock actuator.
It will be snug but def shd fit.
Balance them? If there's a tire vibration, sure. If not, why?
I have a few questions, hope its fine if i put them in one post instead of multi posting =).
1) Did 95 maxima GXE come with a stock alarm? I have an anti theft light that blinks when my car is off. But i don't know how to actually activate the alarm (if there is one) i don't have any buttons on my key, and turning the key to lock the door twice locks all doors, but no alarm is enabled.
2) [edit] I'm sure my car came with wireless key entry. I put the key in and out fast a few times (was actually less that everywhere said, everywhere said 6... mine did it in 4) and the hazards blinked twice. Now, for the 2nd part of the question that i have yet to figure out myself, will any kind of wireless car key work? EX. the universal remote keys on ebay. (search 4ch rf) http://www.ebay.com/itm/4CH-12V-DC-3...item5d30376e75
3) *most importanat* My passenger door key pins seem to be stuck. I can insert the key, but i cannot turn it to unlock or lock. I have to either A) go to driver door and unlock all doors then walk to passenger to get what i need, or b) unlock driver and reach to passenger side to get what i need. This is annoying as sometimes i may be in a hury to get what i need. the door DOES lock if the inside lock is locked via manually(from inside) or power through driver (outside/inside)
4) Is there any place i can buy ALL 4 doors + the ignition cylinder to match 1 key? I remember on an older vehicle i had to replace the ignition becuase the key was not working in it. I then had 2 keys, 1 for doors and 1 for starting the car, i dont want that. If i have to replace my passenger, i want them all to match to 1 key.
Thank you for any and all help given.
~DonnieMo
[edit 1]
Modified first part of question 2, confirmed answer i saw earlier on google
~DonnieMo
[edit 1]
replies in bold
From what i've gathered thus far on the site, all the 4th gens were prewired for the stock keyless entry.
you will need the factory key fob...i dont remember the part number off hand, but i know it's listed many times on this site.
it sounds like one or a few tumblers have come loose within the cylinder. I personally dont know how to repair those besides just getting another one that works and having it rekeyed by a locksmith.
Not sure about being able to buy all of them at once, but again, i'm pretty sure you can just get the new lock cylinders set to operate with your old key.
~DonnieMo
[edit 1]
~DonnieMo
[edit 1]
You currently have 8, but you can't spam-post any of the forums or modpowers will ban your butt :-)
Well damn. Haha oh well. Only 6 posts to go. Btw if anyone has an STi I'm looking to trade (as well as add cash for one).
What years of engines will fit my 95 maxima?
Im not sure what years will work. I have a 3.0 and I found a few for sale but I need to know if they will interchange ones a 99, ones a 98 ,ones a 97! Will any of these years work? Yhank you!
This has all been covered quite a bit, search or just read through AM, you'll find your answers.
Any '95-'01 VQ30 will work, you'll just need to swap your emissions equipment over depending on what you get.
Thank you very much!!
Is the hood lock, 62515, welded onto the upper radiator support? It's free from the lower radiator support by removing the bolts but it still stuck on the upper support. If it's welded should I drill it off then bolt it back up while installing?
Engine Sound: Womp Womp Womp
Per site rules, I'm posting my question here. I'm newly learning DIY car maintenance, so please excuse any ignorance I may have.
When I start my 1997 Maxima SE, the engine make a low, moaning, groaning wooooooooomp wooooooooomp woooooooooomp sound. It generally goes away after the car has warmed up/been driven for a while.
I hear it more clearly while sitting in the driver's seat than with the hood up looking in the engine (not sure why). As such, I have not been able to pinpoint the sound other than generally on the driver's side (maybe in the back) of the engine.
Any ideas on what could be the culprit?
Look @ the "how-to" sticky at teh top of the 4th gen subforum. you pop the corner lights (rearward-most ones) off, then unscrew the one holding the turn signal.
For the fogs, you push up and slide out teh black piece on the inside of the lenses. For my 99 there is no pop-up", just a plastic screw to undo and the section comes out.
Can you hear the blend door switching to the defrost position? If you put it on defrost, where is the air actually coming out of?
Do you have automatic or manual climate control?
I think I know why the new MAF was acting all ****ty....
Is there some crazy requirements to post in there?
