NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Aug 31, 2008 | 12:29 AM
  #1961
Rob20's Avatar
i think dreamcatcher is on the right track, speed limiter i believe is in the ECU that wont let the car accelerate anymore, not really sure about that but i think its worth looking at.
Old Aug 31, 2008 | 09:50 AM
  #1962
FRZ251's Avatar
Originally Posted by DreamCatcher
Is it a US version? Does it have a speed limiter?
Yes the car is US version. Ive heard people on here say they didn't have speed limiters on them.
Old Aug 31, 2008 | 11:07 AM
  #1963
DreamCatcher's Avatar
They do have speed limiters. This is how you can remove them:
http://www.vqpower.com/v2/readarticle.php?article_id=38
This can also be found in the "Mechanical/Maintainence" sticky.
Old Aug 31, 2008 | 02:47 PM
  #1964
allensteiner21's Avatar
only the gxe model came with a limiter, gle and se don't have them. i have a gle and can get up to about 140 by running up to red line with od off and the switching it on...takes a looong time. try getting up to red line in 4th and the shifting into 5th.
Old Aug 31, 2008 | 03:58 PM
  #1965
FRZ251's Avatar
Yea I'm trying to figure out why the car is weak around 6000k-redline, i mean in 1st 2nd 3rd it is, this isnt your average over rev, it like dies at 6krpm, and struggles to get to redline
Old Aug 31, 2008 | 04:14 PM
  #1966
might be air flow issue, clogged injectors, weak coil etc. plus the stock intake manifold is not very hp productive in high rpms at high speeds.
Old Aug 31, 2008 | 04:19 PM
  #1967
Originally Posted by Rob20
Knock sensor -98 maxima auto 170k miles
i want to know if this will fix my problem or not. I recently got the codes from my car and it only said that my knock sensor was bad. Sometimes the car will just die on me out of nowhere.. sometimes while changing gears.. while going slow..in park, at the stop light.. my usual rpm on drive is around 500-600rpm in first(is this the iddle speed?..yes im a noob :P) so anyways i was wondering if i replace the knock sensor on the car will it fix my problem? is there a good chance that it could be. is my RPM normal
also my brake pads dont have any anti rattle springs am i suppose to have them? I have tried many things to stop squealing from my car could this is the problem?
put a 470k ohm resistor in the ks harness plug, reset the codes and see if it helps. if it does than yes, you need a new ks. 500-600 rpm might be a bit low at idle - which is in N or P. the rpm will drop a bit in D if you have an AT. normal idle rpm is about 650-700rpm.
squealing from brakes most the time comes from crappy pads or dirt - spray some brake cleaner on the rotor and pads and see if it helps.
Old Sep 1, 2008 | 12:24 AM
  #1968
Rob20's Avatar
how exactly do you put the resistor in the harness plugZ? is there a special way? where is the harness plug, 470k ohm resistor where can i pick one up, is it expensive. reset the codes throught the code reader thing? reset as in erase code? normal rpm in P is like 800-900 drops to like 500-ish in D..tonight i had it in park and rpm was weird 700 to 500 moving around then dropped to like 300 looked like car was going to die then it rose to 400 wtf is wrong with my car . close to giving up...and ram it against a semi.. o also can a bad knock sensor turn off my car?
and i switched to OEM akebono brake pads and squealing has dropped dramatically almost completely. price diff was like $50 thought..
btw sorry for so many questions i am a car noob ++
Old Sep 1, 2008 | 03:08 PM
  #1969
get on the 4th gen forum and you'll see 2 threads, one about the 470k resistor which'll tell you exactly how to do it. and a second one about the iacv cleaning - this migh solve your idle issues.
the resistor is under $2 at radioshack just make sure it's 470k ohm. a bad ks won't shut the car off. is your check engine light on? can you get codes pulled/cleared at a local autozone?
the ks harness plug - follow the cable from your ks up the line, first plug on it is the harness connector.
Old Sep 1, 2008 | 06:59 PM
  #1970
fusion1620's Avatar
hey, is a 95 a fourth gen Noob....
Maxima wiring harness is way to hard to change.
Old Sep 1, 2008 | 10:16 PM
  #1971
noob means you're new and most likely don't know much, yet
pull the starter and get it tested at a parts store - they'll tell you what's up for sure.
Old Sep 2, 2008 | 06:53 AM
  #1972
Yankel.v's Avatar
Power steering
I wanna to change my power steering fluid, I read a couple of threads on this topic, my question is they say I have to put there Dexron II or Dexron III such as Mobil 1 ATF or Amsoil ATF, isn't it the automatic transmission fluid or this exactly what I have to put there?(Jus want to be on a safe side)
And how exactly do I emty the power steering system, which hoses do I have to disconnect?
Old Sep 2, 2008 | 05:17 PM
  #1973
98_MAX_SE's Avatar
Hey all, I have a very embarassing question to ask. I currently own a 98 Maxima SE. I'm wondering, how do you turn the AC on? It may seem like a stupid question, but I'm not sure how the digital fan settings work. It will go as low as 18C, but thats it. Even then it blows luke warm air at best. Now I've put up all summer with just keeping the windows down, since the weather hasn't been too bad with all the rain... but this rash of hot weather has made me wish it was working. It could very well be that 18 is as low as it goes, and the AC should be on, its just out of refrigerant, but I'd rather ask a free online question than take it to a shop for a test. Thanks a lot guys!
Old Sep 2, 2008 | 05:53 PM
  #1974
FRZ251's Avatar
I have a 99' SE 5spd with the Bose headunit. Does this thing have an AUX port in the back somewhere? I'd like to hook up my mp3 player. Thanks guys.
Old Sep 2, 2008 | 06:02 PM
  #1975
it doesn't but iirc there's a write up in the stickies on how to add it.
Old Sep 2, 2008 | 06:11 PM
  #1976
sophisticated's Avatar
Ok well I don't know very much at all about cars, not saying I don't like them...I love certain cars for there look or how they perform....but my big brother (alicious) loves cars and so I wanted to learn. My question to start out with is what do you think the top ten things are that I should learn first about cars? thanks
Old Sep 2, 2008 | 07:27 PM
  #1977
internetautomar's Avatar
mod or sell?
yes it is the same as the fluid in your automatic transmission.
yes you are probably out of R-134a. the system is designed to automatically turn on the A/C as required by your temperature setting.
Old Sep 3, 2008 | 05:31 PM
  #1978
dcunited99's Avatar
I recently went to get my 95 SE inspected, and was told I needed my steering rack/pinnion was leaking. And it would cost $800 to fix. Is this reasonable and something that is usually expensive?
Old Sep 4, 2008 | 10:29 PM
  #1979
fusion1620's Avatar
Try to find out how much the part costs. This will give you a better idea of what they are charging for labor....
I have a noob question you you. My 95 will not turn over. The starter is good.. Battery is good . Battery terminals are clean and tight.But.. I'm not getting power from the black/red wire at the starter solenoid. what should I check next?? Just bought the book today so I hope that will help narrow it down too. Thanks and Aloha!!!
Old Sep 4, 2008 | 10:41 PM
  #1980
khantalha+'s Avatar
u need a upgraded Intake plenum...they are called MEVI and 00VI..and the search option will be ur best friend
Old Sep 6, 2008 | 01:52 AM
  #1981
fusion1620's Avatar
Got the Maxima running today. The back two screws were loose on the ignition switch.. Thanks for all the input you noobs!!!!!
Na much love. Next time you see a Taurus pass you it just might be a SHO.. Aloha....
Old Sep 6, 2008 | 10:30 AM
  #1982
blackflag's Avatar
in the cylinder firing order where is cylinder number six? my check engine light is on and it's telling me that cylinder #6 is misfiring.
also are there any thread on how to replace your O2 sensors and your EGR system?
Old Sep 6, 2008 | 11:03 AM
  #1983
SexySusieMaxima's Avatar
where to buy new cupholders
Hi everyone! I'm new here obviously. I just bought an older (1997) maxima and I love it. Except for one thing. The cupholders in the front are just the size for soda cans but aren't big enough for water bottles or anything even slightly bigger. The cupholder thing seems to pull right out, so I was wondering if there is any kind of aftermarket piece I can buy to replace it with bigger holes for bottles.
Thanks!
Susie
Old Sep 7, 2008 | 01:30 PM
  #1984
Bryanakahamm's Avatar
new question
I own a 1995 maxima gxe and for the time being, its off the road. I want to rebuild the engine before i upgrade to turbo/nos. are there any good write ups or something that could help me along the way? ive never rebuilt a v6 before. and im hoping that its not much harder.
please & thanks
-bryan
Old Sep 7, 2008 | 04:40 PM
  #1985
kymax96's Avatar
Ok since theres not an all motor noob thread, I'll post this here. I'm planning on putting 3.5 cams in my 3.0 and I had a question about the install. I know you need the adapters, but I've read that they also needed to be drilled, about 183 deg. Is this true, and how would I go about doing this?
Old Sep 10, 2008 | 07:36 AM
  #1986
dcunited99's Avatar
It's time to sell the Max, too much money being spent. Is there a specific thread that would most likely help me in starting to sell my car? Please direct me in the right direction.
Old Sep 10, 2008 | 06:03 PM
  #1987
miso_808's Avatar
filter question
hi, im new to these forums and had a question. I just installed a k and n filter on my car (1998 I30t) and as i finished up, i went to start the car and it died. Then, i realized that I forgot to plug the MAF sensor in but now I have a check engine light even after i plugged it in. I was wondering why this could be. is it because of my IAT dangling in the engine bay or can I just reset my ECU to make it go away? any help would be much appreciated.
Old Sep 11, 2008 | 10:54 AM
  #1988
97HunterMax's Avatar
Need help with ignition, sputtering issue please
I have a 97 and my car has been giving me fits lately. About a year ago I was driving the car and it started sputtering real bad. I would lose power and even downshifting did not help. The engine would shut off. After pulling up the codes and troubleshooting, I narrowed it down to an ignition coil being bad. Replaced it, problem solved. Now, the same symptoms have popped up again. I decided to order and replace all 6 this time. I have also changed the plugs and fuel filter. After installation, car seems to run fine, although I did notice slight hesitaton. Very next day, car runs like crap again. Do more troubleshooting. Pull all the wires one by one and looks as if maybe one of the new coils is bad. Replaced that with the one I bought a year ago. Car idles and runs normally. The very next day car starts sputtering on me again. I lose all power, car shuts down. I check for any codes and it only tells me a knock sensor issue. Do I have yet another bad coil in this bunch or is it possibly a computer issue? I'm at a loss here and would appreciate any help.
Old Sep 19, 2008 | 04:16 PM
  #1989
Naws's Avatar
exhaust
my b-pipe rusted out and now i need to replace it,
since i have to replace i decided i want to make my exhaust sound nice
what is the cheapest way to make the exhaust louder and better
should i just get an aftermarket b-pipe or a full catback?
also i heard something about taking out the resonator on a stock b-pipe, is that a good idea?
Old Sep 20, 2008 | 07:31 AM
  #1990
J RO 9's Avatar
are all spark plugs the same thing? or is there a brand that is preffered/unpreffered by you guys?
Old Sep 20, 2008 | 07:47 AM
  #1991
B_Eaze's Avatar
Get a greddy catback, louder than stock but not fart pipe loud from my understanding. Go check the exhaust thread, they have sound clips of different exhaust set ups. Might wanna change you Y-pipe too, nice gains there.
Nissan suggest NGK, 98% on the ORG suggest and use NGK (including me). they are $1.80 at Advanced auto for copper plugs, well worth it. NGK are the correct heat range for our engines
Old Sep 20, 2008 | 07:53 AM
  #1992
B_Eaze's Avatar
Anyone who wants to do engine rebuilds should get a Hayne's manual and Factory Service Manual. Great help.
I see a lot of quesitons havent been answered in this thread but I've seen all the answers your looking for somewhere before. Try searching. If your looking for answers about cams and motors do a specific search by clicking the advanced search options. Then you can search in specifically the ALL MOTOR section or the TURBO/SUPER Charge section
Old Sep 20, 2008 | 05:29 PM
  #1993
brwnNbrusd46's Avatar
Some are different, but barely. Those new E3 spark plugs have four prongs vs. 2 or 3. It just makes it so the combustion is more even throughout the chamber. I have some E3 spark plugs in my Ford and they improved the performance over the old 3 prongs.
Old Sep 20, 2008 | 05:31 PM
  #1994
I was looking at a 1998 Nissan Maxima SE for sale today. Is there anything I should look out for in one of these used Maximas? What are common problems on a car this old? It had the automatic trans, unfortunately.
Old Sep 20, 2008 | 05:33 PM
  #1995
And what kind of gas mileage do most of you get with your fourth gen auto?
Old Sep 20, 2008 | 05:34 PM
  #1996
I'm just kind of posting so I can open a thread about it. Unless there is one about such a subject already.
Old Sep 20, 2008 | 05:35 PM
  #1997
Any suggestions?
Old Sep 20, 2008 | 05:37 PM
  #1998
My mother used to have a third gen Maxima SE, it sounded wonderful, but it sputtered up hills with the a/c on. Do all early Maximas do that or was something wrong with it?
Old Sep 20, 2008 | 05:39 PM
  #1999
The Bose stereo it had was crap too, but the car was cool. If they hadn't sold it, i'd have it now. darn.
  #2000
Could you swap a newer 6-speed manual into a fourth gen Maxima?
