Illumination on Auto Climate Control Buttons Stop Working Again
Old Apr 6, 2007 | 03:12 PM
matrix11229's Avatar
I replaced my Bose headunit with Premier Deh-p580mp few months ago( I didn't replace the bose speakers).
As soon as I installed the headunit the illumination on climate control buttons stoped working. So I bought new bulbs from the stealership for almost $30 and illumination worked again.
After 2 months one of the bulbs stoped working, and now only the Auto and Econ buttons are lit up.
Also since I installed the new headunit I started getting a slight electric shock when I touch the metal around ignition switch(when I remove the key) and sometimes from the car's body.
I think it's because I connected the "Power antenna" and "Bose Speaker Amp Turn On" wires with Pioneer's "Remote" wire. (In this specific headunit there is no other way to connect these wires).
If I will replace the bose speakers with regular non-amplified pioneer speakers will it solve the problem ? I don't feel like spending $30 on new bulbs every 3 months.
Here's the pic of the headunit:
Old Apr 6, 2007 | 04:23 PM
TurTLe*'s Avatar
oddly when i put in my apline radio my ACC bulb did the same. 2 of the 4 went out. while i had it out i bought $10 for 50 LED and used about 10 total and re-did the entire car. not a problem anymore, i also wired it the same as you but no shock or anything.
Old Apr 7, 2007 | 12:58 PM
I don't have experience with leds , so I replaced them with bulbs.
The only concern is that my bulbs went out twice
Old Apr 7, 2007 | 01:44 PM
TurTLe*'s Avatar
could be just bad filament bulbs. i mean it can happen. the bulb gets thrown around and gets weaker.
oh dude. you can get those bulbs from radio-shack for $3 for 2. there was a couple post back then.
i dont know exactly. but i think these would come close
http://www.radioshack.com/product/in...entPage=family
anything with the two legs like that should fit in. for the AC bulbs on LED you just solder the resistor on the postive leg and run the 2 legs into the bulb holder and wrap it the way you took it off. sand off the bulb a little and your done.
Old Apr 7, 2007 | 09:34 PM
Wow , that's a good idea , I never thought about it.
So I can use any led bulb and put it inside the bulb holder without the resistor ?
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
