High unstable idle after cleaning IAC
Old Apr 10, 2007 | 05:59 PM
Majestic's Avatar
Yahhhhhhh
I cleaned my IAC valve yesterday with some throttle body cleaner. I just removed it and hit it with a tooth brush and sprayed some down the tube also. Now my idle is high (1000rpm) and it bounces slightly but not much. Is this normal or did I jack something up? I cleaned my throttle body at the same time also.
Old Apr 10, 2007 | 06:19 PM
evildoughboi's Avatar
make sure you tightened that valve; i didnt and the car stalled after it successfully started (rpm dropped and continued to do so). also check that the gasket is in ok condition. you might want to replace it since your there anyway.
i kind of have the same problem. the car drives ok but the idle bounces around (from 900 in drive to about 600 - pretty bad, almost stalls at 600) after i replaced the injectors. i tried tweaking the TPS both times and it kind of fixed it temporarily. try turning that screw on the AAC motor to adjust the idle rpm.
im hopefully it'll work itself out for my car.
Old Apr 10, 2007 | 06:28 PM
Majestic's Avatar
Yahhhhhhh
Well It's not bouncing down low at all. Really you'd have to be staring at it to even see it moving so it's not that bad. I can't remember where you adjust the idle. I think that may just solve my problem. I hope your problem gets worked out as well.
Old Apr 10, 2007 | 06:47 PM
heynow's Avatar
black plastic screw on the IACV can be used to adjust the idle
Old Apr 10, 2007 | 06:55 PM
killerVQ30DE's Avatar
Not same prob as you guys but.. I had real low idle at startup and stalling, etc and had to up the IACV valve to bring revs up by 300.. cleaned my TB and boom starts no problems .. lowered rpms back down to 700rpm
Old Apr 10, 2007 | 07:10 PM
Majestic's Avatar
Yahhhhhhh
Black plastic screw?
Old Apr 10, 2007 | 07:11 PM
Majestic's Avatar
Yahhhhhhh
That's a really dirty TB.
Old Apr 10, 2007 | 10:07 PM
Cdg2125's Avatar
ok....the black plastic screw is the Idle Air screw. You can turn that to adjust your idle. As should be expected, after cleaning your IACV the idle will increase. Think about it...lots of dirt slows air. Once it's cleaned air can move in better and rpms will increase. Give it time, your car should adjust and drop the idle. If not in a week or so then adjust the Idle Air screw.
Old Apr 10, 2007 | 10:35 PM
andrei3333's Avatar
the same thing happend to my old buick when i washed the engine, for 2 days idle was high then just dropped to normal
i plan to take off my tb and iacv to clean them in the near future and expect the idle to rise, just adjust to the oem spec 700 no load idle rpm.
Old Apr 10, 2007 | 10:38 PM
mikejw22's Avatar
Did you use replace the old gaskets with new ones after the cleaning???
Old Apr 11, 2007 | 05:03 AM
Majestic's Avatar
Yahhhhhhh
I kept the gasket but it was fine. I'm going to give it a couple days though.
Old Jun 6, 2007 | 01:13 PM
andrei3333's Avatar
so hows the idle ? did it come down or u adjusted it ? im about to do this on the weekend
Old Jun 6, 2007 | 01:54 PM
Majestic's Avatar
Yahhhhhhh
Came down to 700 so now it's normal. It was normal about a week or two after this thread.
Old Jun 6, 2007 | 04:10 PM
Love_00_Max's Avatar
Curious to know, why do you even clean the IAC. Does it get as dirty as the TB and what are the symptoms of a clean necessary?
I clean the TB, once in a year when there is this occasional jerk at low speeds (kind of odd feeling) and when I get to the TB, it actually is dirty but not as one of the above pictures.
Old Jun 6, 2007 | 04:16 PM
f550maranello2's Avatar
DID ya see the pics above?
Old Jun 6, 2007 | 04:24 PM
Are u referring to the TB pictures, wow it looks pretty dirty?
I don't disassemble while cleaning mine, turn the butterfly plate over and clean the back side.
Old Jun 6, 2007 | 09:03 PM
andrei3333's Avatar
if u have idle other then 700 at no load it could be due to a dirty iac valve, it restricts proper airflow to the point where the ecu can no longer compensate for it. also a jumpy idle could be a symptom of a dirty iacv
my idle is at 700 hot no load in P, but as soon as i switch to D it goes to 550 and stays there
BkGreen97
Apr 2, 2016 05:47 AM
97_GXE
20
Sep 17, 2015 08:12 PM
seesole
Sep 14, 2015 12:38 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
sdotcarter
Sep 2, 2015 09:53 PM
