so my car turns of after i race?? what the hell?
Old Apr 10, 2007 | 11:29 PM
adriena's Avatar
everytime I race and I'm at wide open throttle ill be going t the end of my third gear and start to slow down I'll shift into neutral and my car turns off. what could be wrong?
Old Apr 11, 2007 | 12:20 AM
tedo007's Avatar
faster than you think
check your vaccum line or may be its time for you to check your codes
Old Apr 11, 2007 | 01:25 AM
chazmcgee's Avatar
could be a long shot but might be your MAF
Old Apr 11, 2007 | 01:27 AM
supazn
how fast were you going and are you sure your max is the SE version?
Old Apr 11, 2007 | 10:57 AM
adriena's Avatar
i'm sure its the SE version no limiter or anything like that someone else told me I could be getting too much air or somehting like that but the only code i have if for my third o2 sensor witch has an o2 simulator on it. and thats weird to because every other time i got to check the code the reader will say no diagnostic codes but the light will stay on
Old Apr 11, 2007 | 11:12 AM
garyrr's Avatar
stalling on heavy decel could be the IAC sticking closed
Old Apr 11, 2007 | 02:29 PM
Nissan 6's Avatar
stop racing, that might fix it.
Old Apr 11, 2007 | 02:34 PM
NmexMAX's Avatar
dot dot dot ...
The car wont turn off due to a sped limiter, so that throws that idea out the window.
Old Apr 11, 2007 | 02:46 PM
icedout's Avatar
thats what was happening to my friend in his 2000 se maxima but the car dident throw any codes and it was his maf that was bad.He put in a new MAF and hes all good to go now no more problems.
Old Apr 11, 2007 | 10:30 PM
tedo007's Avatar
did you try resetting the ecu??? if you did you prolly jus forgot to turn the screw all the way jus guessing mine did that when i was messing with mine year ago
Old Apr 11, 2007 | 11:08 PM
adriena's Avatar
no i haven reset the ecu i am going to do that and maybe it is my MAF three other people told me that was probably the problem so i am going to try that thanks guys
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
Team STILLEN
Aug 10, 2015 04:29 PM
mrgooch
Aug 9, 2015 11:00 AM
