Dimming lights
Old Apr 11, 2007 | 02:14 PM
Keatz's Avatar
Dimming lights
Hey guys, just wanted to get some insight on something i've noticed for a while. When im holding the switch to get my windows up on the car i notice that my lights dim. Also, my dash lights dont seem as bright any more, any suggestions?
Old Apr 11, 2007 | 02:16 PM
2da mizzax's Avatar
yeah. let go of the button.
udienow's Avatar
Maybe u adjusted the dimmer switch on the dash? Maybe your battery is on its way out if lights dim from simply closing windows... test the battery for free at an autozone or something of the like that does free battery tests.
Old Apr 11, 2007 | 02:25 PM
Cdg2125's Avatar
clean your grounds
Old Apr 11, 2007 | 04:37 PM
Keatz's Avatar
Alright guys, heres an update, i went to autozone, alternator and battery are both okay. But on the way back i noticed something wierd, when i had all the window switches on the driver side in the up position i would here a "click" noise behind the dash (behind the guage cluster). When the switches are up the lights dim but once the click noise happens the lights arent dim anymore. Any thoughts????????
Old Apr 11, 2007 | 04:39 PM
Wolfe's Avatar
That should be a relay if thats where its coming from. the dimming is completely normal... if it gets worse you can always invest in a cap.. I've seen people do that before who aren't running a sound system..
Old Apr 11, 2007 | 09:00 PM
kcryan's Avatar
yep grounds, but i wouldnt worry bout it personally
Old Apr 12, 2007 | 04:12 PM
Keatz's Avatar
Kcryan thats all i needed to hear, doesnt seem like a big problem so i aint gonna do anything about it. But just in case i get bored, and i know this sounds like a really "noobie" question but anyone know where the grounds are????
Old Apr 12, 2007 | 05:44 PM
Batxel's Avatar
blah
Follow the negative cable that comes off the battery. It will connect to the chassis of the car and from there it connects to the engine block. Just pick up a wire brush at your local auto parts/hardware store.
Old Apr 12, 2007 | 05:59 PM
99grnmaxgxe's Avatar
Or if you want a cheap mod, get or make a grounding kit. s
Old Apr 12, 2007 | 06:33 PM
Keatz's Avatar
thanks for the help guys, now i got something to do when i get bored
Old Apr 12, 2007 | 07:29 PM
maxima_kenny96's Avatar
lmfao
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
