Vehicle Speed Sensor HELP PLEASE!!!
Old Apr 19, 2007 | 07:04 PM
stang233's Avatar
OK i ran the code it says vehicle speed sensor. I bought one and replaced the sensor is there anything else i should do. I reset the codes and all. THANKS RICHARD
Old Apr 19, 2007 | 07:09 PM
Dan_E_Boi84's Avatar
yeah drive the car...that's all you need to do...see if the light comes back on.
If it does then you've gotta start from square one...diagnoseing.
Old Apr 20, 2007 | 01:14 AM
kc10fish's Avatar
had the same problem - replaced the sensor and it came back. ended up being loose speedo connections. good luck.
Old Apr 20, 2007 | 11:28 AM
matude's Avatar
did you follow any guides? how hard was replacing it?
Old Apr 20, 2007 | 08:38 PM
It's easy... disconnect connector, remove bolt, and pull out... then reverse to install. Easy as pie....
wingnut2006
Sep 19, 2015 06:13 AM
I<3 A32's
Sep 10, 2015 11:07 AM
sdotcarter
Sep 2, 2015 09:53 PM
