Starter acted funny.....
Old Apr 20, 2007 | 01:12 AM
Maximus_95's Avatar
ok guys... this is really weird...
I tried starting up my car, i heard a loud pop i guess and did not seem normal, so i took out my keys and i heard this loud fan noise....
opened the hood and my starter was spinning very fast i guess, or a loud spinning noise was coming from it, couldn't get it to stop so i unplugged the battery....
Any ideas what this may be?
Thanx...
Peter
Old Apr 20, 2007 | 08:31 AM
pmohr's Avatar
No more Maximas...
When you took the keys out did all the electronics turn off like normal? If you reconnect the battery what happens?
Old Apr 20, 2007 | 08:35 AM
hectorc's Avatar
Upper Midwest Wheel Whore
Sounds like your starter got stuck. i would replace it and try it again. They're not overly expensive, and easy to swap
Old Apr 20, 2007 | 08:45 AM
JSMax's Avatar
Sold
seems like just about everyones starter is acting up these days. Replace it cause it's going to need it sooner or later anyways.
Old Apr 20, 2007 | 09:21 AM
gunny11218's Avatar
i have no idea what it might be. but im going along with JS. my starter is acting up too. its really weird
Old Apr 20, 2007 | 10:26 AM
ComradeJew's Avatar
My starter hates very cold mornings
Old Apr 20, 2007 | 02:22 PM
L0R1DA's Avatar
Sounds like a brush or wiring inside your starter got shorted to ground but just to be 100% check your starter ground, it might be corroded or damaged, and might just need cleaning/replacement . The 4th gen starter has an expiration date of about 10 years (this is accelerated by fluctuating weather and temperature changes), at this point they almost always need to be replaced for one reason or another. I had Maximum Tuning do a 5th gen starter for my 4th gen a few years back (it was also the one thing they did that didnt have problems a few months down the road).
Old Apr 20, 2007 | 03:33 PM
Maximus_95's Avatar
alright guys.... i just had this started replaced less than 2 weeks ago along with my 3.5 swap....
now, we all know the starter is new haha.
besides that, what else could it be?
when i put my key back in, it acted normal, and it started up fine.... just didn't know what could have caused it to act that way...
Old Apr 20, 2007 | 05:32 PM
matty's Avatar
That is your seleniod for your starter getting stuck. My starter did that and I had to replace it. It was kinda freaky cause I thought it was going to blow up...I rushed to get the battery terminal disconnected and it stopped immediatly. Put the battery back on, and it started again.
Before I replaced the starter, I backprobed the starter connecter to make sure it wasnt getting power from the key. It SHOULD NOT have power there with your key out. If it does, then its a different problem
-matt
Old Apr 20, 2007 | 05:35 PM
MDeezy's Avatar
Thanx...
Peter
That happened to me also, it was freaked out too cause it just kept spinning, disconnected the battery and the car started up once I reconnected it. I later replaced the starter, but that was a few months later and that problem never occured again after that time.
Old Apr 20, 2007 | 05:48 PM
matty's Avatar
Mine was so bad that I couldnt re-connect the battary. It had to be replaced right away.
Old Apr 20, 2007 | 06:31 PM
Maximus_95's Avatar
huhmm.....i guess ill get a new even though its only 3 weeks old...but i do have lifetime warranty on it.... i love this lifetime stuff!
Old Apr 20, 2007 | 07:16 PM
JSMax's Avatar
Sold
I replaced my factory starter with a champion re-man unit. It lasted about 8 months and then I had to re-do it. So far, just about 1 year later and it's all good. Even if you get a rebuilt unit, sometimes they are still faulty.
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
